    Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
    Results 21 to 40 of 84
      Oct 2015
      Got a little bit more done on the dash.
      Oct 2015
      Arm was getting sore from beatin' on the dash pieces, so I started working on mounting the radiator.
      Charlotte
      Quote Originally Posted by windows View Post
      I didn't know that. Thanks for the info, Bonecrusher. I really appreciate that.
      Super late on seeing this - but nice parts!
      Are you going to be able to get those paddle shifters wired up and working?
      2014 Chevy SS LS3 / 4 Door
      Oct 2015
      Quote Originally Posted by bonecrrusher View Post
      Thanks Bonecrusher. I looked at an aftermarket controller, but it may be easier/cheaper to buy a good used 4l80e from a C6 that will enable the paddles. At any rate, i plan to get the truck on the road, then deal with the paddles at a later date.
      I see you got your clutch etc. finished. Bet it feels good to get that out of the way.
      Charlotte
      What started out as a fuel pump upgrade - snowballed into replacing the pump, the fuel level sensors, all of the plastic tubing inside both tanks - and replacing the the crossover tube!
      I am just now getting to the engine work that I wanted to start before Christmas. Oh well - it is what it is - on to more fun projects!
      Now That's a cooling system!
      Oct 2015
      Thanks Wayne. It's from Hendrix racing team, but was never used. I had intended to use it for a 396 big bloc, but I think it will work ok for the LS.
      Oct 2015
      Got a little more done on the dash this weekend.
      Oct 2015
      Great project.
      Oct 2015
      Jul 2010
      OREGON
      I love 56 chevy trucks yours is way more hitec than mine.. Can't wait to see yours done.
      Oct 2015
      Got the seats back from Red Green's Upholstery Shop. Did a bit more work on the dash and started the console.
      Nice.
      Los Angeles
      Being from Sudbury I know exactly who Red Green is! Did you have have to drive to the Possum Lodge to pick them up or did they bring them down in one of his wacky cars? :7)
      The rule is measure twice and cut once. My problem is I still measure with a mic and cut with an axe!
      Oct 2015
      Quote Originally Posted by Protour_Pinto View Post
      Yes, in fact he delivered them in the van with the power windows. See link: https://m.youtube.com/watch?v=1uG6grzdUf8#
      Oct 2015
      Still working on the interior, all be it, not very quickly. Got the shifter installed and the ebrake.
      Oct 2015
      Got the right side of the console installed. Just some welding, filler and sanding to do and it will be ready for paint. Recieved my new seat skins and foam, but i won't be doing the upholstery until the rest of the interior is complete. If anyone knows a good way to lenghten an automatic shifter cable, your instruction would be much appreciated.
      Oct 2015
      I used a B&M cable on mine when using a OEM style shifter, works great.
      My half a$$ed build thread.https://www.pro-touring.com/threads/...elle-6-0-4L60E
      Tighten it till it strips & back it off a quarter turn.
      Oct 2015
      Quote Originally Posted by Alwhite00 View Post
      Thanks Al. I googled your recommendation and it seems like it may work.
      Sep 2013
      sw Kansas
      If you can use the associated parts, Morse 33c cables can be made any length.
