    Results 1 to 20 of 21
      Aug 2010
      New Albany IN.
      Lost bleeder fitting
      Hey guy's i went to install my remote bleeder that I bought a while back and sure enough a piece is gone. I need a new fitting that threads into the slave cylinder and the braided line threads onto the other end. Anyone know where I can find one.
      Apr 2012
      Woodstock, IL
      Speedway Motors has a kit, and through that you can find the individual part numbers. Summit or Jegs will also carry the fittings.
      -Dale
      SchwartzPerformance
      Aug 2010
      New Albany IN.
      Thanks just called em. Its Male 10×1.5mm Metric Convex Seat to 3AN Male
      Only 8 bucks but shipping cost $9 lol oh well life goes on :-)
      Beach Park IL
      Don't forget the crush washer. That is what actually seals there when using that fitting.
      Donny
      A proper fitting wil seal on the inside inverted cone inside the slave, just like the stock bleeder.
      Beach Park IL
      Yep, just commenting as the fitting in the picture is not the proper fitting.......and missed the convex part, that should be correct.
      Donny
      Corvettekid...
      I actually have some of the proper fitting if you haven't ordered yours yet.
      Aug 2010
      New Albany IN.
      Thanks Andrew but I had ordered that day. But you two are making me wonder. The kit came with crush washers but you are saying that it doesn't require one?
      Now I'm confused because I read a lot of people having issues with remote bleeders leaking because of them having the wrong crush washer.
      Aug 2010
      New Albany IN.
      Here is a picture of the stock bleeder and the remote bleeder
      Quote Originally Posted by corvettekid1973 View Post
      Post a picture of the bleeder you just purchased. Does it have a cone or is it concave?
      Aug 2010
      New Albany IN.
      Its on it's way. Ill post one when it comes in.
      OK...look in my Cougar build thread and you will see how I was bitching about improper bleeder fittings and the issues associated with them.
      Aug 2010
      New Albany IN.
      Ok ill check it out
      Aug 2010
      New Albany IN.
      Now you have me worried. My bleeder is also a Speedway kit.
      Aug 2010
      New Albany IN.
      The new fitting came today.
      Beach Park IL
      Yep, that won't seal without the crush washer. See Andrew's thread for the correct fitting that I hope he puts a picture of here with possibly a part number maybe for posterity
      Donny
      Aug 2010
      New Albany IN.
      Cross your fingers guy's. The trans is almost done. Im may drive my car today for the first time since I bought it 3 years ago this October
      Not with that fitting. What can happen is that the fitting bottoms out before the crush washer seals. I have a handful of the right fittings and all part numbers are in my build thread.
      Here are the pictures of the Speedway fitting and the proper fitting.
      The proper fitting is on top and has the correct cone on the right side. The fitting on the left is wrong and relies on the crush washer to seal. The worsts part is that the fitting on the bottom will give you a sense of security and make you thin it will seal on the crush washer, but in my experience, it is too long and it will bottom out before the crush washer has any chance to work.
      Aug 2010
      New Albany IN.
      Sorry Andrew I just checked this post. I don't get notifications. Anyways I saw your issue with the cougar so I compared the threads on the speedway fitting and the stock bleeder. It looked close. So what I did was used a fine grain disc and very very carefully polished the end of the speedway fitting almost the where the threads started. I used the thickest crush washer I had.
      I got it all back together and everything bled. No leaks and I drove the car for a couple miles. So if it leaks again ill get a fitting from you or burn the car to the ground
      I just used a random photo to show you the part I polished down
