    Results 1 to 9 of 9
      Feb 2014
      SoCal
      Rear diff ratio recommendations
      1967 Gto
      474 roller motor ported cast iron heads
      All the aftermarket goodies
      600lb tq
      450-480hp
      Turbo 400
      275/35r18 rear tires
      Purely street. No drag
      Looking to have a 12 bolt built. I was thinking 3.27-3.55. I'm told my 10 bolt will break.
      Maybe even 3.08...that's a pretty short rear tire. Even with the 3.08 you will be at over 3000 RPM at 75 MPH.
      Sep 2014
      Sun City West, AZ
      If you are just grocery getting in town the 3.27 to 3.55 will probably feel pretty good with a Turbo 400. The Turbo 400 first and second gears are a little on the tall side. I don't think you will be happy with a 3.08. Now, if you going to cruise a lot on the Freeway, you'll probably be happier with a 3.08.
      Kenny Mitchell
      [email protected]
      Nov 2011
      Livermore, CA
      thanks for asking, want to swap out my 4.11's on my BB 396 4spd Chevelle. I was thinking 3.55's but I want something that will work with the T56 when that eventually happens.
      Livermore, CA
      American:
      1966 Chevelle SS "Tribute" Retro / Pro-Tour
      For Sale
      Feb 2014
      SoCal
      I think the car has 3.30 ish. Running 3k at 65/70 mph. If I go with 3.08 will the car feel like a pig off the line?
      Sep 2014
      Sun City West, AZ
      Quote Originally Posted by Seanprovost View Post
      It may with the tall Turbo 400 first and second gears. But, on the other hand you may be ok with that amount of torque and if your cam is profiled for low-end torque. A good tranny shop that knows how to work on Turbo 400s may know how to change your planetary gear set so the first and second gear ratios will be on the shorter side like a 700R4 first and second gear ratios. The 700R4 first and second gear ratios are 3.07 and 1.62, about a little over of 20% of gear reduction. With those gears you will be alot quicker off the line. The only problem you need to be aware of, the pinion gears in the planetary gear sets are real small in order to get the lower gear reduction and they usually won't handle a lot of torque. You will break a lot of gear sets. I ended up going back to the standard planetary gear set to handle the torque.
      Kenny Mitchell
      [email protected]
      With that much low-end torque, you probably won't miss the 3.36s much, and you'll certainly appreciate 3.08s on the highway.
      Feb 2014
      SoCal
      Just found a complete rebuilt 12 bolt posi in SoCal with 3.31's for 1600.00. Year warranty and the axle width is the same. I can go with a moser unit for 3400.00 so this is a steal. Putting a deposit through PayPal and I will drive down from NorCal to get in the next week or two.
      Feb 2014
      SoCal
Size:  196.8 KBMy original SoCal deal feel through. Found a 1965 chevelle 12 bolt 3.07 posi with new moser cover, axles, Wilwood dynalites, brake hoses, upper arms and e brake cables. Paid 1600 plus freight. Very happy with the rear end. Great gear for my build
