    Results 1 to 12 of 12
      May 2014
      Help me select components for manual brake components
      I'm working on a 67 Chevy II Nova with a 5.3L/t56 swap. I'm having difficulties finding a way to mount my hydraulic clutch master and retain a brake booster within a factory sub frame. This has led me to change my approach and try to design a manual brake system.
      The goals:
      -Must contain mostly OEM or OEM style components. No specialty Wilwood or Baer setups.
      -Must fit behind 17" wheels.
      -Must be easy enough to stop that I can daily drive in traffic without concern. I understand some extra pedal effort but don't need a thigh workout.
      -Aftermarket master cylinders are ok but aluminum is preferred.
      -I currently have a right hand drive S10 1" aluminum GM master cylinder and 98-02 Fbody brakes all around.
      -Spirited street driving is likely the extent of punishment.
      -I'm fine buying higher end brake pads but would prefer something locally available vs special order.
      -I have looked at 325mm C5 rotors and matching calipers but I'm concerned about fitting behind 17" wheels.
      -Car will weigh in around 3000 lbs (maybe less) and probably 245 width tires all around.
      Anybody able to help? Thank you so much in advance. I am truly to a point of frustration with the brake and clutch fitment and it is driving me crazy.
      May 2008
      Dillsboro IN
      I would contact Tobin (Apogee on this forum) at Kore3 with your list of requirements. He will easily be able to help you put a system together, and you will have the comfort of being able to buy replacement parts locally. They also have templates that you can print and cut out to make sure they fit behind your wheels before making the purchase.
      You will not regret speaking with Tobin, you will learn a lot and will have a system that works!
      Any chance you have a part number/source for the RHD S10 MC?
      May 2011
      Chippewa Falls, WI
      Camaro "LS1" Brakes are 12 inch and would be plenty for your car. I would recommend a 7/8 bore master cylinder with adjustable prop valve for the rear. Pads can be any reputable ceramic and can be easily had at any parts stores. Kore3 can set up up with brackets/hubs etc for everything front and rear. Pedal ratio would be ~6-1
      Justin N.
      1966 Chevelle
      1992 GMC Typhoon
      1989 Jeep Wrangler CJ 6.0 Twin Turbo
      1981 Jeep CJ7
      Oregon
      Quote Originally Posted by COPO-RAT View Post
      GM #89056539
      As for going manual, it's all about your pedal ratio, bore size and pad CoF. The assumption is that you'll stick with the factory 6:1 manual pedal ratio. The effective brake torque between the 98-02 LS1 F-body and 325mm C5/C6 is actually very similar, as the LS1 uses a caliper with larger pistons with a smaller rotor diameter relative to the C5/C6 applications. That said, the C5/C6 components are certainly higher performance than their LS1 F-body counterparts, but not in such a way that you'd notice much on a street application.
      It it were mine, I'd probably run a 7/8" or 15/16" Wilwood tandem master cylinder, Hawk HP Plus or EBC Yellowstuff pads and call it a day. There aren't many small bore, aluminum body, GM compatible master cylinders out there, however if off-the-shelf was important to you, then I would suggest the Mopar unit, which are available in both 7/8" and 24mm [15/16"] units. While it does require a little grinding to spread the mounting hold pattern, it's lightweight and uses a plastic reservoir with screw-on caps that don't leak.
      Tobin
      KORE3
      It's what I does.
      Quote Originally Posted by Apogee View Post
      GM #89056539
      Tobin
      KORE3
      I use that Mopar MC and in addition to the grinding for the bolt pattern, you will need to grid on the pushrod a little to make it work. I think I got mine at O'Reilley for about 60 bucks. 1995 Dodge Spirit.
      Oregon
      7/8" [22.2mm] - Dorman #M39736 (91-95 Dodge Spirit w/ 14" wheels)
      15/16" [24mm] - Dorman #M39476 (91-95 Ddoge Spirit w/ 15" wheels)
      It's what I does.
      Jun 2006
      Katy,TX
      When I was looking at the local OReilley for some of the Mopars MC some come cast iron and have the same number, so you may have to sort through a few boxes to get an aluminum one.
      1965 GTO project car
      2004 Pulse Red GTO
      Quote Originally Posted by Skip Fix View Post
      This is the one that I got:
      NMC2412
      It was aluminum.
      May 2014
      Thank you all for your help! I think I definitely have some option based on what is listed here. Andrewb70 I went and looked through your gto build thread and you have a very nice project.
      I also did some research on the Hawks HP+ and EBC Yellowstuff. They look like really nice pads. I think I'm leaning towards the Yellowstuff.
      Question about the pads though: if I stayed with the larger bore 98-02 f body calipers and upgraded to 325 mm C5 rotors would this effectively increase my brake torque. Assuming they fit, this would let me run a higher end "part store" brake pad with similar results?
      I like the Mopar option from the availability and price standpoint but I'm just not sold on appearance vs Wildwood but 7/8" is what I had in mind so I have some options there.
      May 2014
      Also: how much could I move the hole in the pedal before worrying about binding? And how much would be worthwhile? Would moving the hole from 6:1 to say 6.5:1 be appreciable? That would be additional 8% of braking. But also pedal travel too
      Feb 2006
      Houston, TX
      Normally a 6 to 1 pedal ratio equals about one inch of master cylinder piston travel. A 6 to 1 pedal ratio gives good brake pedal placement for the driver and good brake pedal range of motion.
      Going up in the pedal ratio, reduces the master cylinder piston travel and in turn reduces the volume of fluid going to the brakes. Going up to a 6.5 to 1 pedal ratio will increase clamping force by 8%, but you may loose over 13% in fluid volume because of the reduced master cylinder piston stroke if your master piston stroke is reduced by 0.125 of an inch. If your caliper needs any of the 13% of fluid volume, your brake pedal may go to the floor, and your car will not stop.
      You can increase the master cylinder piston stroke when using 6.5 to 1 by increasing the brake pedal range of motion. This means lengthening your pushrod. Lengthening your pushrod will lift the pedal away from the floor and toward the driver's seat. This will require lifting your foot off of the accelerator pedal higher than normal to put your foot on the brake pedal.
      You can also get back your volume by increasing the bore size of your master cylinder, but increasing your bore size will put your back to the same clamping force you had with the smaller bore master cylinder.
      If you go to a 6.5 to 1 pedal ratio and leave the master cylinder in the same mounting location, you will increase the angle of the pushrod. Usually the angle of the pushrod will also get worse as your brake pedal goes through its range of motion. Easiest way to get rid of the pushrod angle is to mount the master cylinder higher on the firewall to put the master cylinder piston's bore in line with the pushrod. Mounting the master cylinder higher on the firewall, will require some additional fabrication.
      The easiest is stay with the factory manual brake position that the factory used (if your car came from the factory with the option of manual brakes).
      Match the master cylinder to the caliper's piston area using the smallest master cylinder possible that will have the volume needed to operate the brakes. Usually a 7/8" bore master cylinder will work in most manual brake applications, but double check your applications to make sure.
      The Chrysler aluminum master cylinder I have had success with is Dorman Brand M39451. It is advertised as a 21mm bore, but it is actually a 7/8" bore.
      If you need adapters to mate GM brake lines to the above Mopar master cylinder you can purchase Classic Performance Part number 45045. There are three brake line adapters included with part number 45045. They have a yellow zinc coating as a rust inhibitor. All three adapters have a 3/8-24 inverted flare male end and three different inverted flare female ends. The inverted flare female ends are 9/16-18, 1/2-20, and 7/16-24. I use these adapters to mate Chrysler master cylinders with two, 3/8-24 outlets to GM brake lines that have a 9/16-18 rear brake fitting and a 1/2-20 front line fitting. The 3/8-24 female inverted flare are common on some Chrysler and Ford master cylinder brake line outlets. The 9/16-18 male inverted flare fittings are used for the rear brake line on many (1965 - 1997) GM car and truck master cylinders. The 1/2-20 male inverted flare fittings are used for the front brake line on many (1965 - 2004) GM car and truck master cylinders. The 7/16-24 male inverted flare fittings are used for the front and rear brake lines on many (1955 - 1964) GM car and truck master cylinders.
      David Schultz
      MalibuDave
      www.manualbrakes.com
      Southern Indiana
      77 Monza has 7/8 bore, might have to do some work to remove a residual check valve but icdoubtvit as the prop valve had check in it last I looked.
      But its cast iron.but will work well for manual brakes from what I heard. Couple guys I know used this one with upgraded g body/s 10 spindles and brakes.
      Lee Abel
      AFTERMARKET PERFORMANCE
