    Results 1 to 19 of 19
      Nov 2010
      LS bracket question
      Does anyone make a bracket for a DBW pedal in a first gen fbody? Also what about a bracket for the ECM?
      Thanks for the help!
      Pensacola, FL
      DSE makes one for use with a corvette pedal. I just installed one in a 67 im building. Uses 2 bolts on the column bracket to mount it to the firewall, Its inexpensive as well.
      Scott
      Do all the GM DBW pedals provide the same inputs to the ECM? Can they be swapped without tuning?
      ​John Parsons
      The Gen IV pedals are all the same in terms of functionality. So if it has the long 6 pin connector, you're good to go. Common pedals are Corvette, CTSV, and my favorite Monte Carlo SS.
      Oct 2014
      I have been told by CBM Motorsports that fbw pedals are application specific, i.e. If your engine is from a cts you will need a cts pedal, id you have a vette motor you will need a vette pedal. I used the DSE bracket on my GTO pedal and with some minor tweaks it worked like a champ.
      Feb 2011
      dallas, tx
      i have the dse bracket. I don't know as far as pedal location goes but it bolts up very nicely and its cheap
      Jul 2009
      Cypress, TX
      Good to know. I just ordered one.
      Quote Originally Posted by icemanrd19 View Post
      1969 Camaro - LSA motor, 6L90 transmission, TCI front subframe, TCI torque arm rear suspension, Ford 9" rearend
      Dec 2008
      Detroit
      Quote Originally Posted by Fourmz View Post
      That's incorrect... The programmer just needs to know the pedal you are using when programming the ECM. Andrew's motor is an L92 with a Monte SS pedal. I have a Monte SS Pedal for my TBSS motor. It should only be 24x pedal to 24x motor and 58x to 58x...
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Feb 2011
      dallas, tx
      Quote Originally Posted by terrydmorgan View Post
      Make sure you have the correct pedal. The dse works with the corvette dbw NOT the camaro. Im going to see what needs to be done so the camaro pedal works.
      Jul 2009
      Cypress, TX
      I have the CTS-V pedal. I'll let you know about any mods that are needed
      Feb 2011
      dallas, tx
      take a pic of the pedal for me. Ill take one of mine and show you the issue
      north central Iowa
      Jul 2013
      San Fernando Valley
      LS bracket question
      I second the Ironworks bracket. I had to modify it but it's real nice. They have ECM and gas pedal brackets.
      Jul 2009
      Cypress, TX
      Here's my CTS-V pedal. And, it fits on the mounting bracket with no modifications.
      Feb 2011
      dallas, tx
      very nice. Yes my pedal does not. Debating to sell mine and buy the ironworks setup or just make one.
      your pedal is offset. Mine is straight down.
      Jul 2009
      Cypress, TX
      Thanks for the tip. My bracket arrived today. Should have it in the car pretty quickly.
      Quote Originally Posted by justanova View Post
      My pedal that came with my LSA crate motor doesn't fit the DSE bracket. I bought one and I'll have to make something anyway because of the different pedal mount. To me it looks like the Iron Works bracket is the one for my pedal it bolts from the side not front to back like Terry's
      Dec 2008
      Detroit
      I welded studs to the floor..... Just a thought
      Chris--
      Feb 2011
      dallas, tx
      isn't there a epoxy or something that someone is using to "glue" fab bosses to a finished firewall?
