      Feb 2015
      ls7 fuel filter/regulator location ?
      thanks for all the help so far. i have another question about filter/regulator location , should i put it near the pump or the motor, i have a mast motorsport ls7 and the instruction don't say that it matters. i was thinking about installing it near the motor , but then i need to run the return line from tank to motor part number for filter/ regulator 10299146, thanks
      Apr 2012
      Woodstock, IL
      On a Corvette (and most GM's for that matter), these are installed closer to the tank than the engine. We always put them right at the back so the return line is short.
      -Dale
      SchwartzPerformance
      As Dale said, like so...
      Jan 2013
      Cypress, California
      X3. By the tank.
      Aug 2008
      jacksonville,fl
      The thinking in near the tank is so fuel has less chance to pick up heat during recirculating.
      Chicago suburbs
      I thought that the closer the regulator is to the motor, the more responsive it (the regulator) is. I used an Aeromotive tank & regulator and they seemed to want to see the regulator at the motor. Either way a pump speed control is probably the best way to keep the fuel from overheating.
