    Results 1 to 20 of 30
      Nov 2009
      the dirty mitten
      Adding toe/camber to a full floater
      I have a Moser circle track full floating rear that I want to add in a little toe and camber to it for obvious reasons. I talked to them today and of course did not recommend it just because their shafts and drive flanges are not crowned so there will obviously be wear and a life span that will need to be monitored.
      What I'm looking for is how to do this, I am hoping for about a degree of camber and toe. The tubing is 3 inch OD, 0.188 wall. The method I heard of is to use heat. I do not have a good enough torch but I have also heard that I could use the welder, basically weld on a hot and heavy bead and when that cools, it will pull the tubing in a little, bending the axle. I can grind that smooth if I want after. Or I think I remember that you can grind a valley out of the tube first, then throw down some beads letting the same method take place
      Steve
