Results 1 to 20 of 30
- Feb 2006
- San Diego, CA
- 166
C5 spindles on First-Gen F-Bodies. . .pro's/con's???
Since I don't have a set of C5 spindles in front of me I cannot compare them to the stock first-gen F-Body spindles. . .I am planning on buying a set of C5 spindles for my '67 Firebird 400 coupe, but thought I would double check the pro's/con's with you guys first. . .
C5 spindle advantages:
- a stronger spindle that is possibly lighter than the stock first-gen F-Body spindle
- wider variety of brake packages available
-I believe these have a sealed hub/bearing construction. . .I guess that could be an advantage and a disadvantage
C5 spindle disadvantages:
- I don't know???
Another thing I am unaware of is the geometry of the C5 spindles; I am aware of the lack of camber gain in compression that the first-gen F-Bodies have. . .wondering. . .
- is the C5 spindle is taller than the stock F-Body spindle-->improving the camber curve. If so, how much???
-what about the steering arm location; improvement for bumpsteer???
These are just the things I have thought of off the top of my head. . .could those of you who have had experience with these spindles please post up. If there is already a post dedicated to this subject you could just post up the link. . .I couldn't find one.
Thanks!'67 Pontiac Firebird 400 RA
http://www.lateral-g.net/forums/showthread.php4?t=7693
'97 Camaro
'00 Yamaha R6
'01 Aprilia RS-50
'02 Yamaha R1
