    Results 1 to 10 of 10
    Thread: engine question
      Sep 2013
      Technically speaking you have a GenIII small block, the 5.3L were LM7s. They have cast iron blocks as compared to the LS1s aluminum blocks. As Mark said, save everything. If you want inspiration, check out my 1967 Cougar build (using a "LS" engine).
      isn't an ls1 also the 5.7l variant
      and isn't the common name fore any of the vortec/ls engines 'lsx' (even though technically this is incorrect since gm makes and sells a specific block that is an lsx block)
      Scott
      '66 Chevelle
      Quote Originally Posted by scott_fx View Post
      I try to be more specific because people think all GenIII or Gen IV engines are LS1s, then they get the engine and it turns out to be a 4.8L from a truck, The platform is similar but there is a tremendous amount of variance in block material, head design, internal components, and accessory drive systems. Not to mention cable TB, vs. DBW, etc...etc...etc...
