    Results 1 to 16 of 16
      Nov 2010
      ls6 intake on a ls2
      I was wondering what I need to do to my LS6 intake to make it work properly on my LS2. Also it had a drive by cable TB on it and I'm putting a drive by wire TB on it (stock ls6 DBW TB) do I need to change anything on the intake for that? It's going in a 68 firebird so the wiring will be set up for DBW and is a 58x reluctor. Thanks for the help
      Apr 2012
      Woodstock, IL
      ls6 intake on a ls2
      You will not need to change anything on the intake. The LS2 and LS6 heads were virtually the same so they both bolt up to each other. I'm not sure if the Ls6 TB will work with the 58x operating system though, that'd be the only potential problem I'd see. But again I do not know.
      -Dale
      SchwartzPerformance
      Nov 2010
      ls6 intake on a ls2
      I was hoping that if I swapped to the DBW set up would work with the 58x.
      Didn't we go over this already? LOL
      Nov 2010
      You said to buy an LS2 intake with 90mm TB. I think I, going to stick,with the LS6 after talking with some friends and looking at the tests done by magazines comparing the flow of the LS2 intake vs the Ls6. And I already have the LS6 with injectors and fuel rails and Sensors.
      Quote Originally Posted by firebirdzig View Post
      So you gain maybe 7HP, but also gain a lot of headaches. It's your deal...go for it.
      Nov 2010
      ls6 intake on a ls2
      That's what I'm trying to figure out. What kind of headaches come with this swap.
      The LS6 intake uses 3 bolt style TBs, while the LS2 intake uses the later style 4 bolt. The early DBW throttle bodies are not compatible with the later 58x style ECUs. So unless you figure out a way to bolt a LS2 style TB to the LS6 intake, this all sounds like a pain in the a$$ with little gain.
      The LS6 intakes are worth more than the LS2 intakes, so you should be able to sell it all, and buy what you need for a hassle free install.
      Nov 2010
      ls6 intake on a ls2
      Ah now I see. Well that sounds like a bummer.
      Feb 2008
      Texas
      Seemed like last time I looked on ls1tech the ls6 intake prices have gone up. At least that's what the members were saying. Though now dorman makes one that's close to the ls6, but is down a few ponies compared to it. So that could change the ls6 prices since the dorman is around $320. You could wait for the msd atomic airforce intake manifold, but they are $950.
      http://www.summitracing.com/parts/msd-2702/overview/
      http://www.youtube.com/user/cutlassrkt?feature=mhee
      69 cutlass - 5.3l L33, Jakes stage 3 4L80e, 275/40/17 proxes tq
      Nov 2010
      ls6 intake on a ls2
      Ya I sold it today for 600
      You should be able to pick up a complete LS2 intake with injectors, rails, and TB for that.
      Feb 2008
      Texas
      man, that's worth it right there getting 600 for it. Makes me wanna sell mine.
      Nov 2010
      Will an Ls3 TB work on the LS2 intake?
      Apr 2012
      Woodstock, IL
      ls6 intake on a ls2
      It will bolt up, yes.
      -Dale
      SchwartzPerformance
      Dec 2008
      Detroit
      Quote Originally Posted by Schwartz Performance View Post
      -Dale
      As Dale said it will bolt up, but you need to check there version. I believe there is an LS3 that opens up the opposite way as the LS2
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
