    Results 1 to 20 of 28
      Oct 2009
      Ithaca, NY
      Fuel Line Plumbing
      Where can I find a good source for designing, installing, and plumbing fuel line from the tank to the rail? Seems like a simple thing, but in my search, I can't find a good source, or primer, on how to do it "right".
      I want to run hard line most of the way, and am having the most difficult time figuring out how to get the line through a box frame rail. Also, what's better: stainless line or AL? Which is easier to work with? Many more questions as well...
      Apr 2012
      Woodstock, IL
      Not sure of where to find the info you're looking for..
      However, stainless is "better" because it is less likely to corrode, and holds up to harsher circumstances.. But aluminum is way easier to work with and bend. We've used both with success. Stainless may be better for flaring and installing tube nuts/sleeves onto because of it's strength, but aluminum conforms easier...
      I guess I don't have any solid answers for you, sorry! lol.
      Going through a frame rail you could use a bulkhead fitting, or bore a hole through and weld a piece of tubing in for the line to go through.
      -Dale
      SchwartzPerformance
      Oct 2009
      Ithaca, NY
      Yeah - I figured a bulkhead fitting, but I don't see any readily available to go through a 2" rail, either in NPT or AN.
      Quote Originally Posted by ProTouringCuda View Post
      For the love of all that is good and holy, please don't use NPT...It's for house plumbing...LOL
      Oct 2009
      Ithaca, NY
      NPT with a conversion to AN
      Oct 2009
      Ithaca, NY
      This is WHAT I'VE BEEN LOOKING FOR!!! Thru-Frame 3/8". These are VERY common for brake lines, but the only place that I've found them for fuel is Pure Choice Motorsports.
      http://www.purechoicemotorsports.com...rod/prd346.htm
      You should consider Cunifer (copper/nickel alloy) tubing, though I've used aluminum and SS too. But once I worked with Cunifer, I'll never go back to SS again. SS is just difficult to work with in so many ways.
      http://store.fedhillusa.com/38fuelhydraulicline.aspx
      ​John Parsons
      John,
      If that fitting is bare aluminum modern ethanol blended gas will attack it. If you go with it, get it hard anodized first. I also hate that it has NPT thread, which means now you have to get a NPT to AN adapter. This is just adding potential leak points.
      Personally, I would make my own bulkhead fitting out of some aluminum tubing, but make it big enough that I can run some PTFE hose through it. Or just drill holes and use rubber grommets to protect the hose.
      Oct 2009
      Ithaca, NY
      John
      I appreciate your experienced reply - I'd never heard of Cunifer before - and an experienced mechanic friend never had either.
      I will go the Cunifer route - this is exactly the kind of knowledge I'm looking for!
      John
      You'll love the Cunifer. Easy to work with, attractive, and will last forever.
      ​John Parsons
      Feb 2012
      SW, Michigan
      I agree with this statement, and with having that logic I was surprised when I had to figure out that the edelbrock fuel rails I bought had npt at the ends.
      Feb 2012
      SW, Michigan
      I also had a talk with Aeromotive tech and they stated not to use hard line on a FI engine due to the pulsing of the injectors being heard through the hard line.. Anybody else have any info on this??
      Oct 2009
      Ithaca, NY
      OK - so I got 12' of Cunifer delivered today. It's in a coil. What's the trick to straightening it out?
      Feb 2011
      Indpls, IN
      Oct 2009
      Ithaca, NY
      Quote Originally Posted by Jetfixr320 View Post
      Home made tool to straighten tubing,
      http://mearcatmini.blogspot.com/2011...ake-lines.html
      Heading down to Lowes tomorrow in search of rollers!
      Seems a bit much...
      Use the following method at your own risk. I am not responsible if something bad happens. OK? (also don't judge me!)
      Unroll it as best you can. Attach one end to something very solid. Attach the other end to your truck or some other vehicle. Using the vehicle, slowly pull the tube straight. It will come out as straight as an arrow. Just be careful and don't pull your house off its foundation.
      ​John Parsons
      Oct 2009
      Ithaca, NY
      That's funny stuff right there - Visions of YouTube video's of how NOT TO straighten tubing just appeared in my mind...
      Batesville, IN
      JP - -what types of flares have you done on the Cu/Ni alloy for fuel lines? 37deg? or do you do all double flare fittings?
      Brandon Wiedeman
      1972 Suburban
      Wiedo's
      Aug 2014
      Bakersfield, CA
      Here's another one from Eastwood that is more reasonable @ $80.00:
      http://www.eastwood.com/eastwood-han...6-1-4-3-8.html
      Oct 2009
      Ithaca, NY
      Quote Originally Posted by silverbullet99 View Post
      Yep - I bought this one. Works very nicely.
