      Jul 2009
      Cypress, TX
      Measure Driveline angle using Tremec iPhone app
      Perhaps people already know about this, but it was news to me. Tremec has a free iPhone app that's really useful. Mainly, you can use it to measure your driveline angles by holding your iPhone at 3 different places on your driveline: 1# engine/transmission; 2) driveshaft; and 3) rear end (see pic below). It measures each angle and gives you a pass/fail for your setup. I was happy to receive a passing grade for my setup. But, I was a little confused by this statement, "angles that are ‘equal and opposite’ are most desirable." My engine/transmission angle was 1.1 degrees and my rear end angle was .9 degrees. I have a TCI torque arm rear suspension, and thus, my rear end angle is adjustable. So does that mean I should adjust the rear end angle to 1.1 degrees as well?
      Here's a link with info on how to use the app: http://www.tremec.com/menu.php?m=154
      The app can also be used to calculate vehicle speed for a particular rpm; or it can calculate engine rpm for a particular cruising speed. You have to enter transmission gear ratios, rear end ratio and tire height (it has a tire height calculator too).
      1969 Camaro - LSA motor, 6L90 transmission, TCI front subframe, TCI torque arm rear suspension, Ford 9" rearend
      Aug 2008
      jacksonville,fl
      heard of it , but haven't got around to trying it with my android phone yet.
      Here's a pretty clear cut demonstration of driveshaft angle effects on travel that I wish I'd seen years ago. I have a faint up & down osculating vibration at some highways speeds, which sounds like bad angles.
      http://www.elcaminocentral.com/showthread.php?t=128185
      Jul 2009
      Cypress, TX
      That's what I needed to see. Great info, Thanks!
      Quote Originally Posted by jlcustomz View Post
      Also keep in mind that the pinion angle will change some under power.
