    Results 1 to 9 of 9
      Petersham ,ma
      nova tire options?
      So I'm doing my 71 over... dse tubs and ridetech suspension and Tru turn....so I know it will take a 315 /30 /18 in the back but what about the front? Car is a street car...was thinking maybe the bfg rivals,
      as available tire sizing is limited . So for front tires I have a choice of a 245/40/18 or 275/35/18 In the fronts. As of now I'm leaning towards the 245's as the 275s may be tight.....any input??
      What's everyone else running for tires and sizes?
      Cincinnati Ohio
      275/35/18 will fit, I run that on my nova.
      Is there some rubbing, yes. Bad? no.
      1972 Nova Ridetech, Forgeline, Falken Tires, Wilwood, Bowler Performance Transmission, Lingenfelter Performance Engineering.
      Mar 2013
      Beaufort,SC
      Tru Turn should be able to fit a 9" or 10" wheel maybe with a 275 tire with some rolling of the fenders to help.
      Petersham ,ma
      I wouldn't mind the 275 's I just don't want to get into cutting up inner fenders to gain a inch not worth it on a non track car.
      Those that run 275 now what are you running for back space and when you say they rub a little bit is that like full lock rubbing or on a hard bump or what? Thx !
      Petersham ,ma
      Anyone got pics??
      Cincinnati Ohio
      Here is my build thread. https://www.pro-touring.com/threads/...n-at-a-project
      I ran stock inner fenders for over a year with a 18x9.5 with a 275, and then I changed a few things on the front of the car, and cut the inner fenders and fenders up, you CANT see that they have been cut unless you look VERY hard. I will get some better pics for you.
      ridetech tell you to run 5.75" BS on a 10" wheel. I run a 9.5" with with 5.5" BS with a small custom spacer. Don't go off my car since I have a custom Wilwood brake kit.
      Petersham ,ma
      Thx!....seems you could run a 9" with a 275 too to gain a bit of clearance as well..like I said not to that point yet but I will be buying tires in next month or so for mock up purposes.
      Petersham ,ma
      Quote Originally Posted by Bad94 View Post
      Nice build! Any more pics of your exhaust? Especially where it goes over the axle....I will need to do something of that nature
      Cincinnati Ohio
      I will see if I have any better pics of the exhaust.
