      Jun 2010
      Deployed
      QuickTime to T56 bolts??
      Can someone tell me the size and length bolts I need to bolt the magnum to the quicktime bell? I assume the bolts are metric but I have nothing to run in and check
      thanks!
      I forget the size, but once you figure it out, here is a good source for them:
      http://www.mcmaster.com/#metric-flan...screws/=vgorrr
      I just pulled a stock T56 to F-body bellhousing bolt and it is 10mm and 40mm long. Now you just have to figure out the pitch, because I don't have a pitch guide.
      Just using my caliper it looks like 1.5 pitch, but you should confirm that. The factory bolts a grade 8.8.
      Jun 2010
      Deployed
      Wow...Thanks. Is 8.8 good enough? Seems like that's what Quicktime is selling.
      The OEM bolts are 8.8, so I see no reason why that's not good enough. If you want 10.9, McMaster has those for you.
