    Results 1 to 10 of 10
      Aug 2009
      wisconsin
      How To Paint your engine using automotive refinishes
      After seeing posts every once in awhile where someone asks what is best for painting their motor, I thought I would share my technique since I could take picures through the procedures while painting an engine this past weekend.
      First off, this is the way I do it. I do it this way because it works well, and the paint holds its gloss and doesnt peel off. I realize some may do it other ways, but I Dont want to turn this into a discussion for what I should or shouldn't have done. Helping out my fellow pro-touring fans have a great looking engine is what this is about.
      Get your engine cleaned. I like to use gunk foamy engine cleaner for the heavy cleaning. A screw driver, some kind of a pick, a small acid brush with the bristles cut down, these are all tools I use to scrape and clean with.
      When the heavy cleaning is done, and rinsed off with water, I go over everything again using a small brush with stiff bristles, and brake cleaner. Brake clean is cheap, and it works well. Work small areas and rinse with water, Dont let the brake cleaner dry out before you rinse with water.
      Dry the engine with your air hose. Blow everything off several times.
      If there is casting flash on the block or any imperfections that you want to get rid of, now is the time.
      If there is rust on the block in places, now is the time to gut rid of it. Wire brush, wire wheel in a drill, small air grinder with small abrasive pad all work good. But get it clean, that's the most important.
      Block off all the threaded holes you will be needing to use. And tape off the intake and exhaust ports. Dont just put a piece of tape across the intake ports either. Use an intake gasket and trace it onto the tape. Then cut the tape and pull the extra off. Pay attention to the details. It makes a difference! The last thing you want to see is a strip of bare metal on the heads right above the intake manifold when everything is put together.
      When everything is blocked off that you dont want paint on, its time for the wax and grease remover. Apply it to a clean dry rag, wipe a small area, then use another clean dry rag to wipe off. Do not apply or spray wax and grease remover directly to what you are painting. Try to use some lint free rags if you can. When the rags get dirty replace them and keep wiping.
      Next go over everything with your air hose and blow everything off. Be careful not to blow the tape off. Then you want to use a tack rag. Get all the dust and residue off the engine.
      This is what I had after these steps. A nice clean engine ready for paint.
