      Carson City Mi.
      Big block fuel injection question
      I bought a multiport fuel injection unit many years ago for my build. The unit is cutler brand it has a 2000cfm throttle body on it and I believe 42lb injectors and is for a big block chevy. My motor was recently assembled and when we went to install the intake we found out it was made for a tall deck big block. After searching the net I found the company is no longer in buisness holley bought them out. Since my motor is a standard big block not a tall deck my thoughts were to buy a new intake from holley the one they use for the commander 950 and move my throttlebody,injectors and rails over to the new intake. I spoke to edelbrock and affordable fuel injection and they both said that a 2000cfm throttle body and the injectors are to big for what I need. My car is mainly going to be street driven the engine should make around 600 horse and is 10 to 1 compression full roller and running edelbrock rpm rectangle port heads it is a 454 . Holleys web site for the commander 950 has a 2000cfm throttle on it so why would the one I have be to big. Not sure if I should just sell the unit or try to use the parts off of it to try and save some cash. This is my first experience with a after market injection system so I really dont no to much about them. Any thoughts would be appreciated. Has anybody had any experience with edelbrocks multiport kits.
      I would just get the right intake and swap all your parts over. The 42 lb/hr injectors will work just fine, they may be a tad big, but not grossly big. The 2000cfm throttle body is not a problem either. I see it has a progressive linkage so no big deal.
      The main issue is that that throttle body requires a 4500 series intake. You'll need to see if Holley still offers it.
      What electronics do you plan to use?
      Edit...Looks like you a re in luck:
      https://holley.com/products/intakes/...parts/9901-202
      Carson City Mi.
      Thanks for the reply Andrew. I was looking at that same intake to use and was figuring the electronics were out dated and should be changed. Do you have any recommendations? I see there are quite a few companys making the electronics now dont know what I need for sure. Would the new electronics plug in to my injectors and sensors.
      Quote Originally Posted by Rich G View Post
      Rich,
      I like the new Holley EFI system very much. I will be using the Dominator system on my Cougar build, but that might be overkill for you if you don't need auto trans control or drive by wire throttle body control.
      Given that you your current hardware is not optimal, you may want to just sell the whole thing to a guy with a boat (which is what it was designed for) and just get new hardware and the Holley HP system.
      So...get this:
      https://holley.com/products/fuel_sys.../parts/550-500
      Plus the right intake for your application. The kit above has some extraneous hardware, so you might be better off getting everything ala carte.
      Carson City Mi.
      Thanks again for the advice I will just end up trying to sell it and put the money into another unit.
