    Results 1 to 10 of 10
      Apr 2013
      Knoxville, TN
      Pro-Touring Corvair
      I have always wanted a pro-touring machine and since my '63 Corvair is getting close to the end for the engine, I think it is time for a serious redux. My plan at the moment is a sbc front engine, rear wheel drive set-up with a rear mounted radiator with eletric fans to push/pull air. At the same time I will switch to front disc/rear drum 5-lug brakes with custom front and rear suspension to remove the swing arm. I have seen a lot of front engine EM Corvairs but almost all of them look like a gasser with its nose stuck in the air. This is NOT want I am aiming at. Has anyone seen one done tastefully in the Pro-Touring style?
      Jul 2011
      Plano, Texas
      What you need is the suspension and drivetrain from a 2005 or newer 911 turbo, aka 997. This will have a AWD system and such. Now that would be sick.
      Michael Mosley
      1968 Barracuda
      Plano, TX
      https://www.pro-touring.com/threads/...in-Plano-Texas
      Apr 2013
      Knoxville, TN
      That would be an amazing setup. I have talked to some people on corvaircenter.com and I am liking the idea of using a g-body chasis and sectioning the corvair body over it. I am going to post a quick sketch as soon as I get near a scanner.
      Apr 2013
      Knoxville, TN
      This is a quick sketch of what I am thinking.
      Name:  Dream Ryder 2.0.jpg
      Cincinnati Ohio
      I know of a corvair that was just finished and is in some testing right now. Car should be badass when all dialed in.
      1972 Nova Ridetech, Forgeline, Falken Tires, Wilwood, Bowler Performance Transmission, Lingenfelter Performance Engineering.
      Welcome - I'd go with a Ls Motor to save weight on the front end
      Apr 2013
      Knoxville, TN
Size:  256.2 KBAt this point the motor is going to depend on what happens down the road, b.t I would prefer an LS. Here is a pic of the car I am going to be using
      1963 Chevrolet Corvair Pro-Touring Project
      1964 Chevrolet Corvair Coupe Rat Rod/ Patina Thing
      2012 Mazda 3 I Sport Sedan
      Mar 2014
      Mesa, AZ
      I've seen a mid engine Corvair before, it was awesome. Is that something you'd consider over front engine?
      Nelson
      Quote Originally Posted by BMR Sales View Post
      or you could a Slip in a V-12 in Front for a Total of 20 Cylinders!
      Apr 2013
      Knoxville, TN
      I did consider a mid-engine since they are pretty common as far as V8 corvairs go. The reason I don't want a mid-engine is a) The degree of difficulty for service and b) one of my goals is to keep the back seat.
