    Results 1 to 9 of 9
      Oct 2006
      Pittsburgh Pa.
      Alignment turntables, where to get a pair?
      Who has a good deal on alignment turntables?
      Thank you,
      Jeff....
      Apr 2012
      Woodstock, IL
      Only ones i've ever seen are all pretty expensive.. I've seen some DIY turntables in the past, google that.
      http://www.summitracing.com/parts/sps-99750/overview/
      SchwartzPerformance
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by pitts64 View Post
      Thank you,
      Jeff....
      Hi Jeff,
      I carry 3 brands around $700 a set. You can see them HERE. I prefer & use the Joe's Racing, as their stuff is always super nice & well made.
      Best wishes.
      Southern Indiana
      a quick note you could also use 2, 12 in square 1/4" thick pieces of lexan, get a counter sunk allen head bolt around 3/8 or 7/16 drill and helicoil bottom piece use white lithium grease between and only tighten up screw enough to hold them together, trim bottom of bolt flush and tada. Ill see iff I can find the actual set of plans i have.
      also look around on Ebay, wheeltronics, John Bean, Hunter, and several others all use same balls for replacement and looking up Stempf part number and googling can get you new balls easy enough as long as rings and springs inside are good.
      Lee Abel
      AFTERMARKET PERFORMANCE
      Oct 2007
      Union Mo
      Check some of the older auto or tire shops. I bought a set from a local tire shop that had been there for years.
      May 2010
      Mooresville, NC
      I made my own using 2 pieces of 12x12 aluminum with wheel bearing grease between them...works perfectly!
      Marc Battiste
      1969 Camaro
      LY6/T56/12 Bolt
      Mountain Springs, Texas
      I got a set for a good price on eBay. Not the best but I don't use them a lot.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Sep 2001
      Accord, NY
      Ebay for me too. I've done about 6 alignments on a few projects and this fits my needs. It was a couple of years ago but I believe I paid about $100 plus shipping. Again, they're cheap but suitable for my home hobby need.
      68 camaro - SOLD
      Aug 2011
      Connecticut
      I built a set, 12"x12" 1/4" steel plates and trailer hubs with bearings. . . its hood as f*ck lol
      1967 Firebird "Poor-Boy Build"
      New updated thread
      https://www.pro-touring.com/threads/...bird-(Updates)
      Follow me on Instagram @NaturalLivingMan
