Thread: T-56 Slave Bleed Questions
07-14-2014 #1
I sealed up the clutch system over the weekend and started to bleed the system. I bought the remote bleeder kit from Speedway Motors (and the AN fittings and line for the pressure side). I am using a vacuum pump that I have had for years.
Here is the bleeder kit I am using: HERE
I have probably pulled a pint of fluid through the clutch without cycling the pedal more than a time or two. I am still getting air. I have never bled a clutch before, so I'm not sure how long it should take. Also the bleeder screw on the remote assm is very small. I am pulling fluid, but I wonder if I'm pulling a little air from around the screw/hose connection.
Here is my setup:
In the picture below, you can see the small bleeder fitting/hose sitting on the frame rail over next to my brake line by the steering box. Any tips or anything? I am planning to put an adapter on with a smaller piece of hose to see if that helps. Then I will just keep bleeding. No leaks over night so that's a good thing. I did cycle the pedal once after to see how it felt, but I don't have anything to compare it to (seems easy, plus there's no driveshaft in the car either). Still feels very easy.
