    Results 1 to 15 of 15
    Thread: GMPP 454 Kit?
      Dec 2013
      GMPP 454 Kit?
      Hi all,
      Looks like Jegs and GM have a new kit available for the LSX454.
      http://www.jegs.com/i/Chevrolet-Perf...ductId=2675108
      Can someone help me understand what else is needed to make this engine turn-key?
      From what I can tell, it's only missing the front assembly.
      Apr 2012
      Woodstock, IL
      GMPP 454 Kit?
      Yeah the front drive and flywheel/flexplate and all that jazz.
      -Dale
      SchwartzPerformance
      Dec 2013
      Thanks, Dale. Have you used these kits before? Also, can you be more specific on "all that jazz" :-)
      I'm not an engine builder, but I can put stuff together. I'm just wondering if this kit would allow me to build a turn-key 454. I don't want to deal with tuning and other stuff.
      Apr 2012
      Woodstock, IL
      Quote Originally Posted by dhanks View Post
      I was just referring to the transmission & such.
      You'll need to fine-tune it after its running, but this kit will give you a baseline to start from and at least get it running.
      What are you putting this into? Most people go with other oil pan kits, since the GMPP has a pretty deep sump (ground clearance)
      -Dale
      SchwartzPerformance
      I don't see an accessory drive with that kit.
      The oil pan is a throw away, since it hangs too low. The rest looks good.
      Dec 2013
      Just realized this is an 8-bolt crank - so that's a no-go since I'm using a T-56 6sp.
      What a hassle it is to get all of these things in order!
      Why no go? Just get any clutch designed for a LSA engine and use that with the T56. A stock LSA has a dual disk clutch.
      Dec 2013
      I want to use a McLeod RXT clutch with it.
      Do they offer it with a flywheel for the LSA engine? If so, you're good to go...If not, there are a ton of excellent clutch options, and personally I would not over look the stock LSA clutch. It seems a little odd to base an engine choice based on the kind of clutch you want to run.
      Apr 2012
      Woodstock, IL
      They do offer a clutch & flywheel kit for an 8 bolt... part number 6405807M from McLeod, steel flywheel .
      -Dale
      SchwartzPerformance
      Santa Clara, CA
      American Powertrain also offers an 8-bolt Science Friction flywheel that lets you adapt a regular 11" clutch to it--although it does sound as though you have your clutch selected. But as Dale pointed out, you're in luck, if you have your heart set on a McLeod, they make a setup for this flywheel. Sounds like you will be sitting pretty!
      Steve
      Santa Clara, CA
      GMPP 454 Kit?
      What have you decided to do?
      Steve
      Dec 2013
      Hi all,
      Just an update here. I decided to go with GMPP LSX454. It's an 8-bolt crank, and luckily McLeod had an RXT clutch kit to make it work with my T-56. McLeod was nice enough to swap out my existing clutch kit and get me what I needed.
      Oct 2013
      Ct
      Any pics ?
      Dec 2013
      I'll start a build thread shortly. I have tons of pictures.
