    Thread: QA1 ride height
      Utah
      QA1 ride height
      I have a 67 firebird with QA1 single adjustable pro coil system. I cant get the front end level. I raise the the right side a 1/4" the left side goes up. Lower the left the right goes down. Im off 1". Whats up?
      Mission Viejo, CA
      I know this will sound silly, but check to make sure that the shocks they sent you are the same length. I had the same system on my car a few years ago and had the same issue. After chasing the problem, I finally realized the shocks in the kit were not the same. I was sent two different lengths. I had to return the wrong one for a correct length shock.
      1973 Hurst Edition Pontiac Grand Am: 430 CI of ERL built LS7, Tremec Magnum T-56 6-speed, Global West / Speedtech Suspension, Custom rear coil-over suspension, QA1 double adjustable shocks, Wilwood 6/4 piston disc brakes, Modulare C1 19" concave wheels. Shooting for 625 HP and 20 MPG!
      Utah
      Even if the shocks were diff. They are not. Why would raising one side raise the other? I have the right side coil raised 1" more than the left but the right side is still 1" lower. Could the sway bar be messing me up?
      Sep 2011
      Southern Ontario
      Different weight springs maybe?
      Utah
      That does not explain the fact that adjusting one side affects both sides.
      Sep 2012
      San Diego
      is the front sway bar connected?
      try it with the sway bar disconnected.
      71 maverick.
      71 comet in build process.
      i work at Current Auto Performance www.currentautoperformance.com. i also build the differentials for San Diego Gear and Axle.
      Quote Originally Posted by bryant View Post
      Ride height should be set on a flat plate, without the sway bar being connected. Once the height is set, the sway bar should be installed, again on a flat plate, with the car at ride height. Doing it any other way might preload the suspension.
