    Results 1 to 20 of 35
      East, Tennessee
      1986 Buick Pro-touring T-Type
      Well the time has come to sell our test car and move onto another project. This car has been to Many ASCS pro-touring events and has been seen by Many here on this board at those events that can vouch for the car and it's performance. This car drives as well as it looks!
      If you have any questions or would like to see more pictures please shoot me a PM and I will give you my number...
      $32,000
      For video of the car in action please visit us on Youtube: http://www.youtube.com/channel/UCqRCQUhhK3Yz-kNqmdHQ7gw
      For detailed suspension/Brake pic's see links below:
      BAER Brake Install thread: http://www.turbobuick.com/forums/thr...nstall.343546/
      DSE Suspension Install Thread: http://www.turbobuick.com/forums/thr...-build.329141/
      ridetech Tru-Turn & Shock Install Thread: http://www.turbobuick.com/forums/thr...nstall.397417/
      1986 Buick T-Type Specs’
      Engine: Freshly Balanced & Blueprinted by Richard Clark & Myself (2012)
      • I have the blueprint sheet that Richard Clark & I did showing all measurements of the engine!
      • J&E Pistons .20 over with J&E file fit rings done by myself
      • Carrillo “H” beam rods w/ ARP L19 rod bolts
      • Seal Power bearings (2012)
      • ARP Main studs – New (2012)
      • ARP Head bolts – New (2012)
      • Stock heads w/ stainless steel valves & new Viton seals – New valve job ( 2012 )
      • Alky Control Progressive Methanol injection – New Pump in 2012
      • H&R Poly motor mounts
      • 55lb Injectors – (Matched & Flowed)
      • TE-44 Turbo w/ Garrett exhaust Housing – Freshly rebuilt by "Bison" (2012)
      • Blue printed Oil Pump by Richard Clark – New in (2012)
      • Comp Cams 206-206 flat tappet cam – New in (2012)
      • Eastern Performance Front mount Inter-cooler
      • 3” Stainless Steel down pipe with RJC waste gate puck installed
      • F-body aluminum radiator
      • 160* T-stat
      • Intrepid Dual fans
      • Built 2004r trans, 500 boost valve, billet servo, alto clutches.
      • Protorque 3000 stall (Spragless) Non lock up converter w/ all fins Tig welded
      • GNS Cold air intake
      • LT1 MAF
      • Stock Ignition with custom fit MOROSO Ultra 40 wires
      • Extender programmable chip
      • Translator Plus programmable box
      • GNS Carbon Fiber Core support braces
      • Custom one off baffled oil pan by RJC Racing for Auto-X / Road racing
      • Power logger data saving software installed onto OEM computer
      • New Quick Ratio steering box (2012)
      Exhaust system:
      • Dual ATR 3” stainless steel exhaust with Pit bull mufflers
      Interior:
      • Pro-car Elite 1100 seats by Scat with custom Suede inserts
      • Suede head liner
      • Suede upper door panels
      • Stock rear seats custom upholstered to match the fronts
      • Suede rear deck lid
      • Whole interior dyed black
      • New black carpet
      • Custom made GNX style dash with white faced Phantom Auto-meter gauges and LED lights as turn signal markers. Also has the ALKY turn on and low level lights built into the face of the dash cluster.
      • Pioneer stereo with remote (New 2013 )
      • Rockford Fossgate Component speakers & Tweeters in front. (New 2013)
      • Pioneer 3-way speakers in rear deck lid. ( New 2013)
      • Scan master
      Suspension:
      • Front- Ridetech's NEW “Tru-Turn Upper & lower A-arms (with Delrin bushings) with caser tuner slugs. (New 2013)
      • Front- DSE frame braces
      • Front- DSE Sway bar
      • Front- Ridetech Single Adjustable Coil Overs (New 2013)
      • DSE - Steering Shaft
      • Rear-Ridetech Single adjustable Coil Overs (New 2013)
      • Rear- DSE Upper adjustable control arms (with DSE’s swivel link ends)
      • Rear- DSE Lower adjustable control arms (with DSE’s swivel link ends)
      • Rear- DSE Sway bar (Chassis mounted & adjustable)
      Wheels & Tires:
      • Made by CCW (Classic Custom Wheel) 3pc racing wheels – weigh 20lbs ea.
      • Centers were black brushed anodized along with the center caps
      • All locking black Gorilla lug nuts
      • Front: 18” x 9.5”- 4.75” back spacing
      • Rear : 18” x 10” - 4.75” back spacing
      TIRES
      • Front: BFG KDW2 255/35-18 ( New Sept 2013 )
      • Rear: BFG KDW2 295/35-18 ( New Sept 2013 )
      BAER Disc Brakes:
      • FRONT- BAER Track 4 featuring 13” rotors with 4-piston calipers, new OEM spindles, new bearings, stainless steel lines.
      • REAR- BAER SS4 system featuring 12” rotors with 4-piston calipers, Emergency brake set up, braided Stainless Steel lines, new e-brake cables
      • BAER proportioning valve
      • GNS Proportioning valve bracket
      • MCSS Vacuum brake system
      Special Features: These items were done by us (GNS Performance) as this was our test bed for many products….
      • Tabbed smoked headlight covers
      • Custom trunk upholstery
      • Smoked marker light covers
      • Sequential LED Taillights (Not just bulbs either, these are actual boards with 187 LED’s)
      • Amber LED front Marker/Signals (Same style as above)
      • LED 3rd brake light
      • Custom made emblems inside & out on the car
      • Brake proportioning bracket
      • Translator plus bracket
      • Carbon Fiber Line-Loc bracket
      • Headlight screens for both the inner headlights (For cold air entering for the intake)
      • Tachometer/Alky bracket (Holds either a Tach or the Alky controller)
      • Carbon Fiber radiator top plate
      GM High Tech Performance - May 2011
      Name:  GHMTP plaque 003.jpg
      Cover of GM G-body Performance
      Name:  LG book cover.jpg
      DSE Add car for G-Body line
      Name:  DSE Add #2 2011.jpg
      Name:  GNHTP 1024X768   2.jpg
      Name:  GMHTP 1024x768.jpg
      Name:  GNHTP 1024X768   3.jpg
      Name:  Resized GNS engine pic.JPG
      Name:  GNXray interior 1024x768.jpg
      1986 Buick T-Type
      RideTech, DSE, BAER Brakes, Forgeline Wheels, LED lighting, More!
      * Get your Top of the line GPS Theft recovery devices Here!
      www.GNSperformance.com
      Price?
      East, Tennessee
      Price?
      Pretty fast with the gun there! I wasn't done editing ....
      1986 Buick T-Type
      Jun 2010
      Painted post NY
      Wow...that car ROCKS! I love GN's....love the white! GLWS!
      Leon Reed
      1978 Trans Am
      LS1/4L60E
      my build..updated 11-21-13 https://www.pro-touring.com/showthre...8-TA-LS1-build
      Janesville, WI
      If I had $32k laying around, I would not hesitate. Very tasteful build!
      -Shaun-
      L92/T56 Stalker 1711 pounds, LS power!
      73 Buick Century L92/T56 swap in progress
      East, Tennessee
      Thanks for the kind words guy's..... The Only reason for selling is to start a new project otherwise I wouldn't even think about it..... The money, time, effort in this car is far north than what I'm asking, someone will get one hell of a car for the money! This car has finished 30th or so out of the last several ASCS pro-touring events which had 80+ cars entered. The driver is holding it back! LOL
      1986 Buick T-Type
      Mar 2010
      Okinawa, Japan
      Man I love this car, good luck with the sale! In case anybody doesn't think so, this is an amazing deal. I know I have north of $25k in mine doing EVERYTHING myself including paint/ body-work and this is A LOT more car!
      Aug 2011
      Clearwater/FL
      Totally worth the 32k
      GLWS!
      88 Blazer sbc
      05 300c
      East, Tennessee
      People like Bill Howell, Yancey Johns, Brian Finch, Danny Popp, Kyle Tucker, Doug Lutes... have all been in this car and know this car pretty well and can vouch for it if anyone is wondering who they can speak to about it..
      1986 Buick T-Type
      Aug 2011
      North Platte,NE
      That is a smoking deal, if I could I would be driving it home NOW! AND its fricken WHITE to boot!
      Nacogdoches TX
      What are kidneys going for these days??
      Nacogdoches TX
      I want this car!!!!
      East, Tennessee
      Quote Originally Posted by rayy View Post
      I want this car!!!!
      It's here waiting on ya! LOL
      1986 Buick T-Type
      East, Tennessee
      Bump to the top....
      1986 Buick T-Type
      Belle Plaine, MN
      Great deal for someone! Good luck with it Scotty!
      Scott Parkhurst
      East, Tennessee
      Quote Originally Posted by Scott Parkhurst View Post
      Thanks Scott !!
      1986 Buick T-Type
      East, Tennessee
      Bump to the top...
      1986 Buick T-Type
      Woodbine, MD
      Sad to see this go.......DONT DO IT!!!!!!!
      This is an amazing car for the money!! (do you take payments?)
      Douglas Lutes
      1988 Monte Carlo SS
      East, Tennessee
      Open to offers!
      1986 Buick T-Type
      Nov 2011
      Good luck with the sale on this!
      I've looked at your car over and over in the past, following the build, etc. because I had a GN for a brief time when I was younger and have always wanted to get one back in my hands, and yours is definitely the way I'd want to build it.
      If I didn't have a '70 SS/RS Camaro with all the same Detroit Speed goodies you have in the garage, I'd be beating down your door! I just don't have room for both!
      I know projects come and go, and I'm sure your ready to move on, but whoever gets it from you is LUCKY!
      All the best!
