      Apr 2012
      American Powertrain ISO-X Transmission Mount
      So I was installing my new American Powertrain Tremec TKO 600 into my 70 Trans Am. I noticed the transmission mount that APT sent was a very stiff block made of this military ballistic material. It basically feels like a block of wood or hard plastic. Anyway, I am running new motor mounts but they are rubber because no one sells poly engine mounts for a 70 trans am ( that year was unique). Solid mounts yes, but not poly.
      As a rule of thumb, you are not suppose to use a poly trans mount with rubber engine mounts do to the different amounts the 2 materials flex. If the engine mounts flex more than the trans mount then you run the risk of cracking the transmission case.
      I am concerned that mixing the ISO-X mount with rubber engine mounts would cause a serious problem since the rubber engine mounts would flex more than this ISO-X trans mount. I called American Powertrain and they claim that it is ok to mix the 2 mount materials without the risk of cracking the transmission due to it not flexing as much as the engine is.
      Does anyone have any concerns with this? Anyone running one of these new ISO-X mounts with rubber engine mounts? Here are the details on the new mount design
      The transmission mount from American Powertrain is called the ISO-X Mount. Here is a link.
      The new ISO-X transmission mount for GM delivers the isolation and vibration reduction of rubber combined with the nearly indestructible 1500hp twist rating of a solid mount and the oil resistance of polyurethane.Made from a specially formulated polymer that is used in ballistic armor, ISO-X has unique vibration absorption properties not found in other materials, and because of its incredible strength there is no need for a steel backbone, the source of vibration in polyurethane mounts. Best of all, ISO-X is not affected by petroleum, petroleum distillates or other automotive fluids which translate to a lifetime of durability.
      The ISO-X is suitable for street, strip and road course use. ISO-X is currently available in standard and low profile heights for popular GM manual and automatic applications including TKO, Muncie, T10, Richmond, Powerglide, T350, T400, 700R4, 200-4R, 4L60 and 4L80. All ISO-X transmission mounts come with a comprehensive warranty against failure,
      Mountain View, CA
      Have you asked APT?
      True T.
      My blog
      Apr 2012
      Yes but those sales guys don't know much. Looking for feedback from someone that has experience with this mount.
      I would use a rubber transmission mount if you are running rubber engine mounts.
