    Page 1 of 6 1 2 3 4 5 6 LastLast
    Results 1 to 20 of 110
    Thread: AutoBahn F-100
      Aug 2010
      now In Dandridge, Tn.
      AutoBahn F-100
      This is a project we've been putting together for a while. Kai from "Street" Magazine in Germany has been hard at work to put this project together and get everyone involved on the right track. They are going to build an F-100 in their magazine, and then take it out to the AutoBahn and the Nurburgring. Of course we were excited and eager to be on board. Here are the basics.
      No Limit Big-10 chassis, plumbed. Floater upgrade. Aluminum tank upgrade. Engine truss plate upgrade. Drop out battery box upgrade.
      347 stroker Ford W. American Powertrain 6 speed. AFR cyl heads. Comp Cams. Canton oil pan. Edelbrock intake. Probe pistons. Mallory ign.
      Chassis add ons include Ride Tech shocks, Flaming River Rack, and Wilwood Brakes.
      The truck will have Automete gauges, IDIDIT column, Painless wiring and Russel plumbing.
      19" OZ wheels and Dunlop rubber will provide the grip.
      Aug 2010
      The rear axle is a 9" with floating axles. 31 spline True Track. Rear suspension is standard Big -10 trailing arms, ride Tech coil overs - rocker arms mounted. The rockers are 1.6 ratio, so a 5" stroke coil over yeilds 8" of suspension travel. Panhard rod is below the axle CL, 36" eye to eye. The trailing arms are ported, and the rear brake lines travel inside the arms. The front pivit is an adjustable "Monster Ball". The billit block is a brake distribution block. It has a single feed in from the back side, a bledd port, and two outputs for the rear lines.
      Aug 2010
      The crusty block is there for two reasons. 1. to make sure everything fits. 2. it helps with the import hassles if there is a 'motor' in it. One tired 302. check. The shifter position is perfect, as long as you set the motor back 2". So the truck will be fitted with a Direct Sheetmetal firewall. Pedals will be Wilwood tandem brake with a balance bar, and a seporate clutch pedal and master. We plumbed the chassisto two #3 brake line fittings, flex lines will connect the master to the chassis plumbing. The plate with the large oval hole in it is for the battery. Our stainless drop out battery box mounts here. The new engine 'Truss' mount adds rigidity and makes future swaps a breeze by only changing the bolt-on reciever. Ford W, Ford C, Lima and Mod (Coyote) all fit the same truss.
      Aug 2010
      We won't see this all together in mock up. From here it gets crated to ship out to Germany. Ill get Kai to take this thread over and post up build picts.
      Aug 2011
      Sevierville, TN
      Awesome!! This looks like a fun build.
      Matt Kenner
      68 C10 stepside
      If you can leave two black stripes from the exit of one corner to the braking zone of the next, you have enough horsepower. - Mark Donohue
      NC
      Its a shame all that work has to be covered up.
      It looks amazing, great job.
      Lookin forward to seeing it updated after it makes its long trip across the pond.
      subd
      Feb 2013
      Nice! I can't wait to see this one finished.
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      May 2011
      Northwest, MO
      Cool build! I will be interested to see what it runs at the Nurburgring.
      Tyler Gibson
      There's nothing like building up an old automobile from scratch and wiping out one of these Detroit machines... That'll give you a set of emotions that will stay with you... Know what I mean? Those satisfactions are permanent...
      Jun 2012
      South Lyon, MI
      Nice work as always. I really like this one. Lots of nice technical touches.
      May 2013
      Moody,Al
      Quote Originally Posted by Tig View Post
      subd
      What he said!
      Aug 2010
      I get a lot of questions about rear brakes on floaters. It's pretty easy. We make the adapter ring, to attach the rotor to the hub, and the weld on caliper mount. We have a two piece bolt together fixture that bolts around the axle housing and holds the caliper mount square during welding. At this point there is no E-brake, this truck will use a spot caliper on the yoke. We have also put secondary caliper mounts on the housings for small mechanical calipers on the rotor. Twin calipers per rotor and turning brakes can be done as well. this set up is a 13" x 1.1" rotor with a Wilwood Superlight caliper with 1.625" pistons. The second two picts show the housing in articulation and you can see the rocker movement.
      Mar 2010
      When you design a chassis, in this case minus the body. How do you figure out the brake package without knowing the final weight, corner weight, etc?a
      Aug 2010
      I guess the answer is "experience". but really, We keep really good records of vehicle weights, spring rates, sway bar sizing, and brake systems. And, with having built over 100 F-100 in the past 20 yrs, you gain a lot of knowledge. Also, a very smart friend of ours gave me a cool spreadsheat that calculates brake balance vs. caliper/rotor/wt/wheelbase. I'd like to publish the work but I promissed to keep it tight. - property values and all. If you need any help with brake balancing let me know. - our C-10 count is up to 53 already. So we are gaining good info.
      Mar 2010
      Cool. Just curious. I have a feeling that smart friend is the same one who triggered this question from another thread. I'm very busy reading as I'm trying to sort out the next phase of my truck. As you can tell by my profile pic - I'd be curious about the maximum wheelbase on that spreadsheet... I'd also be curious about if you can reco engine set-back.
      But enough about chevy's; this is a Ford build thread. Super happy to see this build btw. We need more variety. Cool stuff.
      Jul 2004
      Braselton, Ga.
      Awesome build....your workmanship says it ALL!
      Mar 2011
      San Bernardino, Ca
      Hey Rob,
      I have my "Ring Card" I am offering my services to drive the truck at the Nurbergring.
      Dale
      Nov 2012
      Hi Rob, Just a quick question about the truck arm suspension. Have you found that using square tube instead of the stamped steel factory style truck arms help much with handling capabilities of the vehicle and if so would round DOM tubing work well also?
      Love all your builds BTW keep it up
      Chris
      Aug 2010
      Hmm, here's what I know about trailing arms. Well, a bit of it anyway. One way or another, there has to be some 'Twist' in the arm, if you want the axle to rotate freely. By that I mean, 'tip' to one side. We want to use sway bars, shocks, springs, and roll centers to control and exploit body roll in a corner. - Not suspension bind. The OE truck arm has a fixed bushing and although it is rubber, it doesn't have much twist. But, the OE style I-beam construction does twist, pretty easily. As far as the OE goes, the twist is OK. Welding the arms, boxing them and adding urethane bushings (all the current hype) may be better for drag racing or high speed open track stuff, but will yield a stiffer ride, and cause the rear suspension to be a little less compliant on the street and short coarse. IMHO, round or square tube trailing arms with fixed urethane bushings may be the worst. No twist in the arm or the bushing. We use a square tube arm to reduce torque flex during acceleration and braking, coupled with a urethane bushed "Monster Ball" adjuster to allow plenty of twist, for full axle rotation. It's the best approach we have come up with.
      Nov 2012
      thanks for the info rob that all makes perfect sense. I noticed that on the TCI C10 it looks like they are doing a truck arm with a torque arm all with heim joints all to reduce torque flex? and would just adding an upper link to a stock truck arm set up help with this?
      Nov 2010
      Awesome build, is that trailing arm setup something that you would sell?
