    Results 1 to 9 of 9
      Oct 2013
      Which sound deadener
      They range from 45 mill to 110 mill. dose it matter?
      Mar 2010
      I'm sure others will chime in but I just bought that cheap peel n seal & did my doors, kick panel area, quarters, tray package & back seat area. Cost about $50. You can really tell on the doors when you shut them. They feel solid and don't have that empty metal sound. Just my 2 cents
      Oct 2012
      Brown Deer, Wi
      I found some roles of cheap stuff at a swap meet for $28 just for my doors n under some panels. Just used spray adhesive. Im using the pre cut stuff for the floor. I can go look up the brand if you wanted.
      Feb 2009
      N.J.
      I went the other route, full Dynamat. I got some great deals on Ebay and covered EVERYTHING, including the firewall and the insides of the doors. I may have gone a bit over board but it made a HUGE DIFFERENCE.
      Sep 2013
      recommended is 25% coverage of deadener (not the home depot peel and stick stuff) then full coverage of a sound absorbing material. You can go overboard if you want it as quite as possible (i'm doing 100%) but 25% will get you the best results per dollar spent. I highly recommend rammat http://www.raamaudio.com/
      Scott
      '66 Chevelle
      Oct 2013
      Thanks for all the feed back guys.
      Sep 2013
      Quote Originally Posted by dragonfly jones View Post
      here is a great test comparing the two. 25% coverage using a true deadening material vs. 100 % coverage using peel 'n stick.
      http://www.caraudioclassifieds.org/f...-question.html
      tl:dr--- it ends up being cheaper, lighter and less expensive using the real stuff.
      Scott
      '66 Chevelle
      A lot of good info here:
      http://www.sounddeadenershowdown.com
      Dec 2009
      cave creek az
      I just got done using second skin product on my Chevelle, it came out great! My father-in-law used all dynamat on his and you can hear a difference between the two. I highly recommend second skin, check them out its worth it.
