    Page 2 of 2 FirstFirst 1 2
    Results 21 to 24 of 24
    1. #21
      Central CA USA
      I would try the auto trans cooler in the radiator. I asked Lee about that and he didn't seem to like the idea but didn't have a reason other than those have the flat plate type cooler and was worried about the vibrations.
      Here is our second gen ps cooler, an auto trans type.
    2. #22
      Apr 2003
      Central Valley, CA
      Quote Originally Posted by BLUE72CAMARO
      Could you plumb your powersteering into a transmission cooler in a radiator if you are running a manual tranny? I picked up a used be cool radiator that was for an automatic but I am running a manual transmission so I was wondering if this was possible. But I dont know what kind of psi is generated in power steering and automatic transmissions systems.
      I've been doing exactly that for the last 6000 miles or so. No problems yet.
      Troy
      1969 Chevelle
    3. #23
      Aug 2005
      Patterson, NY
      I wouldn't feel confident with the power steering fluid running through the radiator's transmission cooler unless it was the return side. Automatic transmissions run up to 300 p.s.i., but power steering goes higher. I don't know what pressure the P/S systems run, but I think it is two to four times the A/T system. The P/S system uses hydraulic hoses and fittings, and hydraulic systems run 3000 p.s.i.
      Aeroquip has special hose for P/S lines.
      Again, if you run the cooler on the return side, which will not be as effective, you should be fine. The return handles very little pressure.
      My .02!
    4. #24
      Mar 2003
      Boringville
      power steering coolers are always plumbed through the return side
