    Results 1 to 7 of 7
      May 2010
      Ballwin (St. Louis) MO
      Diveshaft question
      OK. I know this is a dumb question, but I have to ask anyway. Being this is my first build, of this kind, I have to ask, what is the average diameter of a driveshaft and how far should the floorboard/tunnel be away from it? The reason I ask if because I am workinging on floorboard pieces on my project now.
      I think that anyday you wake up sucking air on your own is a great day!
      Used to be known as V8 Square
      http://www.markwilliams.com/driveshafttech.aspx
      You want at least 1/2" between the body and any moving driveline parts.
      May 2010
      Thanks.So, what is the average diameter of a driveshaft?
      Quote Originally Posted by V8 Square View Post
      There is no such thing. The link I posted outlines the specifications that you can use to determine the driveshaft that you use.
      If you want a quick easy answer, I would leave enough room to accommodate a 4" diameter shaft.
      May 2010
      Thank you
      Aug 2009
      Charlotte, NC
      Its really a factory of money and Horsepower
      formula: smaller Diameter x more HP = Mucho Dinero or larger diameter x same HP = a little less cash... Then of course exotic material can offset diameter to achieve the same HP...
      Oct 2012
      British Columbia
      I would say it depends on your build and your goals. For example, I've got just under 500hp and want to keep my car as light as possible so I will be going aluminum (CF is out of my budget). On sizing I will be ordering something good up to 800hp'ish as I plan on future upgrades.
      http://www.summitracing.com/dom/sear...m%20driveshaft
      Todd
      '14 ZL1, 6 speed and 6.2L of Super Charged Awesome!
      '67 Camaro SS in process. A long, slow, expensive trip...
      How hard can it be...
      Project Obsession
      https://www.pro-touring.com/showthre...ject-Obsession
