Results 1 to 12 of 12
- Oct 2011
- 467
Feeler Infinity LS3 Project over 90k invested
1968 Camaro Project, Clean title in hand
Near 70k in ALL BRAND NEW parts not including the body (which is killer!)
Body is very straight, gaps are tight. Body is mini tubbed, with Lizard Skin in and out. ZERO
rust!
Firewall will be completely smoothed and painted.
Front suspension is Ride Tech with Varishock coilovers installed.
Here is what I have been done so far including a list of most parts
https://www.pro-touring.com/threads/...t=infinity+ls3
I can send an Excel spreadsheet with parts listed. OR SEE REPLY #7 IN THIS POST
I also have Ring Brothers- no logo- door sills( $360.00) that also came in today
I am thinking I may sell as I am getting ready to build a custom home.
To finish car
Paint
Door panels
dash pad (I do have a pad that just needs recovering)
driveshaft
rear end
Brake line (main line)
Uber Fueler Module (Squash Performance)
Intercooler (s) I was going to Have Ron Davis make two coolers, so I
wouldn't have to delete or re engineer hood latch parts Cost was same as
one large intercooler
install everything
tune car
I also have a new E85 module that goes with this to make it a flex fuel setup.
This will be every bit of an 800 hp, $100,000 car when finished.
I don't need the money, just trying to move a little sooner.
$55,000 with all parts and body
OR
$15000 for the MINITUBBED and smoothed firewall body which has:
over 6k in parts excluding the brand new subframe (Ride Tech Tru turn suspension ($2000), front Varishock coilovers ($625), DSE ceramic coated power steering box ($695), Flaming River tilt steering column($500), Wilwood front billet hubs $200), Wilwood front rotors ($200), DSE minitubs ($350), Lizard Skin ($400), MCC Firewall plate ($300), pitman arm, idler arm, powder coated swaybar with Energy Suspension endlinks and bushings $300, BMR Del Rin body bushings ($219), BMR weld in subframe connectors ($200)
The new subframe was $1100 plus $200 to paint it (used John Deere Blitz Black epoxy)
Labor performed on the body includes:
Install Minitub $2000
Install Front suspension, subframe, body bushings, weld in subframe connectors, tack on firewall plate, spray Lizard Skin $2800
Smooth rear body seams, smooth and panel bond seams under car, weld in tulip panels and lower door hinge panels, weld in custom rear frame
inner support brackets, smooth inner wheel wells, smooth trunk bottom, panel bond and smooth seams under car set all body gaps, prepare all body panels for final paint, seam seal interior, rain gutters, etc etc. $4000
Smooth firewall (finishing up now) $600
I will only sell all other parts once someone purchases the body (with above listed parts installed)
If not, I will finish and sell for much more or keep it.
Look at my build, there is nothing else quite like it.
Car is located in San Antonio Texas
Can help set up shipper as well.
