    Results 1 to 11 of 11
    Thread: efi carb
      Jan 2013
      efi carb
      Who make the best efi carb? And why ?
      Jan 2013
      Mississippi
      I've only heard positive things about holleys.
      1968 Dodge Coronet Deluxe
      Build thread:https://www.pro-touring.com/showthre...t-Deluxe-Build
      "Make it three yards, motherf***er, and we'll have us an automobile race."
      Cornettsville, ky
      efi carb? whats that im not up to speed?
      Jul 2009
      ma.
      He is talking about efi in a carb look alike from fast or holley . I was thinking about buying 2 for my blown big block but for the price I do not know if its worth it. They seem like throttle body efi systems on old chevy trucks.
      Like to hear how they really are over a carb.
      Dec 2010
      Fredericksburg, VA.
      He is referring to a TBI (Throttle Body Injection) unit which typically looks similar to a carburator and generally bolts on an intake manifold in place of the carb. I would recommed that the OP read the threads on the fuel injection section. Lots of good information and product reviews. The current generation of TBI are much easier to install and program than in the past.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Please post technical questions in the appropriate forum. The Open Discussion forum is not a catchall for tech questions.
      Apr 2007
      NH
      Unless you are making more than 600hp it is the Holley Terminator, hands down. The ECU is identical to their HP EFI unit and is laptop programmable, a necessity for fine tuning for best performance. I've got 4K miles on mine and it is running perfectly.
      69 Mach 1 H-code Restomod 418W/TKO600/RMP Front Coil-Over/TCP Manual R&P/FR Tilt Column/GW Subs/GW Lowering Leafs/GW Del-A-Lum/Factory Power Front Brakes/3.70 9" Auburn Diff/Painless Wiring
      Project Pics
      http://s63.photobucket.com/albums/h127/chillininnh/
      Jan 2013
      efi carb
      And how much would multiport EFI be do holley sell one for Oldsmobile
      Feb 2008
      Texas
      You might want to try the realoldspower forum. I remember there was on guy with a mpfi setup.
      http://www.youtube.com/user/cutlassrkt?feature=mhee
      69 cutlass - 5.3l L33, Jakes stage 3 4L80e, 275/40/17 proxes tq
      Apr 2007
      NH
      Quote Originally Posted by cutlassmann View Post
      Huh????
      Project Pics
      Dec 2008
      Detroit
      The Holley HP retrofit kit comes with everything you would need for a start. You would then need to get some injectors and have the supplied bungs welded to an intake. Bernard Mondello sells the Pro Comp intake that would probably work for that.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
