      Under Lake Michigan
      Commander 950 Wideband instuctions?
      Hey-
      Looking for any instructions or directions or diagrams for the wideband add on for the Commander 950 TBI 4bbl injection setup. I bought a used setup from a friend.
      The holley website only has the kit instructions but I don't see anything about the wideband. The addon unit has a couple of extra two wire connectors that don't seem to correspond with the original holley harness. But the harness I have has been hacked on a little.
      THANKS!!!!
      Mike
      15 Camaro 2SS 1LE summer ride
      00 Yukon work ride - parts hauler
      69 Camaro LS Turbo - project car
      Quote Originally Posted by boneheadzz View Post
      Hey-
      THANKS!!!!
      Mike
      Mike,
      This might be a question for Doug Flynn at Holley, but Ill give it a shot.
      If you have the older C950, you may not be able to use the wideband. The software has to have the ability to impute the voltage curve that the wideband controller outputs. This would generally be a linear 0-5v signal. I forget exactly what version of the C950 software has this feature.
      Under Lake Michigan
      Andrew,
      Thanks for replying. I bought the entire system off of a buddy and he used the wideband on it as well. I haven't had tried hooking anything up on my car as of yet. I wanted to get most of the wiring sorted out first. My biggest question is what these two extra 2 wire plugs are for and the other two little two single wires. If anyone has a wire schematic for this or a pin out it would be greatly appreciated. Does Doug Flynn frequent this forum or do you possibly have his email?
      Thanks again.
      Mike
      Mike,
      Have you read through this:
      http://www.holley.com/data/Products/...99R10323-1.pdf
      I bet if you call Holley Tech support, they will email you older instructions that cover the PN of your controller. I recall those two loose wires…I think you clip them for something, but I don't recall why. They come looped from the factory. Sorry, it's been years since I've messed with the C950 stuff.
      Under Lake Michigan
      Dude-
      You saved my bacon! Sweet. Thanks for the info there. I didn't see that one on the site. Everything I needed was on there. One connector was not used on the commander 950 kit and the other is for a wideband gauge. And the two loose wires was a wire to be cut or not cut depending on what o2 sensor you use.
      Thanks again!
      On a side note, I love the GTO! I've seen it before in Car Craft I believe and think its cool you can get a big car like that to handle and perform. I'm trying to get off my butt and do SOMETHING to one my cars. Keep inspiring others with your hot rod!
      Later.
      Mike
      Dude-
      Thanks again!
      Later.
      Mike
      Mike,
      Glad I could help and thank you for the compliments!
