    Results 1 to 20 of 20
      Sep 2013
      Lexington, Mass
      Rear gear ratio choice?????
      Hey guys, I'm putting a 4l80e into my 72 chevelle mating to a 5.3 truck engine. It will be putting down roughly 450hp. I want the car to take off quick but be enjoyable on the highway. I'm running 25in tall tires. Stuck between 3:55 or 3:73... Any help?
      Thanks, Anthony
      "Never let anyone tell you how to live your life, the only way to be happy is to follow your passion"
      1972 Chevelle SS clone
      1968 Caramro RS--in the works
      2013 Silverado 2500HD Duramax Z71 appearance package
      Apr 2012
      Woodstock, IL
      With that small of a tire id do the 3.55.
      -Dale
      SchwartzPerformance
      Sep 2013
      Lexington, Mass
      dale, thank you very much!
      Jan 2013
      Cypress, California
      I agree. Go with the 3.55 ratio.
      Sep 2011
      So Cal
      I have a 4l80e - 3.73 cruises nicely - I drive a lot!
      Aug 2005
      Hamilton, NJ
      25" rear tire? that seems short on that car. that is like a 215/60/15 in height. what size are you running?
      Scott from NJ.
      Vent Windows Forever! ...
      Sep 2013
      Lexington, Mass
      sorry its a 26inch. theyre 295/35r18's in the back. but i have a somewhat urgent question. i have the opertunity to pick up a really nice 12 bolt all set to drop in with an eaton posi but has 4:11 gears. any comments? im really tempted the guy is asking 1400. later on swap out the gears. like i said im running a 4l80e
      Dec 2010
      Fredericksburg, VA.
      The 4:11 will be fun around town but unless you have a double overdrive IMO it will be miserable on the hiway.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Jan 2011
      Boston, MA
      Quote Originally Posted by chevy4life View Post
      If that were for a Camaro, I'd be all over it. 4.11's with my 6 speed would be perfect.
      Sep 2013
      Lexington, Mass
      just found out it was rebuilt 10 years ago and never even put in a car... im going to get it friday. if i hate the gears in the spring then ill just swap them.
      Jan 2011
      Boston, MA
      Are you going to swap them out yourself? If not, you might be close to the cost of a brand new rear end by the time you're done.
      Sep 2013
      Lexington, Mass
      No I won't, I have a close family friend who does them tho. The guy wants 1200 bucks for it. I debated on going brand new but can't justify spending 3 thousand right now
      Aug 2008
      Iowa
      You will enjoy the gears. I have a 4l80e with 3.90s and love em.
      With a 5.3L, I would run a 3.73 gear.
      May 2010
      Ballwin (St. Louis) MO
      What about a 4:11 with 700R4?
      I think that anyday you wake up sucking air on your own is a great day!
      Used to be known as V8 Square
      Nov 2012
      I run a 3.31 with my 700r4 and have 285/35/r17's.With the converter locked it turns around 2400@80mph. I'd like a little more gear but to be honest it's happy with the 3.31's so why worry with it until I change the whole rearend. If you highway drive it much I'd surely go to the 3.55
      1970 Camaro restomod power tour ride
      1966 Buick Special restomod, the never ending project
      1970 GTO My newest retirement project, time to gather parts!
      Ontario, Canada
      Quote Originally Posted by V8 Square View Post
      Keep in mind that a 700R4 has a rather steep 3.06:1 first gear ratio. Running 4.11s with the 700R4 would give you the same overall gear ratio of a TH350 running 4.95s in the rear (if my math is correct).
      Ken
      My other car is a Vega.
      May 2010
      The reason I ask is, I have a narrowed 9" in mt 2" x 3" tube chassis, VW Squareback station wagon project car. The gear assembly is a new, never installed, 4:11 with my 700R4 and sbc 350/330 crate motor. Really hate to have to buy a new set of gears if i can avoid it.
      Nov 2012
      1st gear will be virtually useless with that much rearend gear in it unless the tire height in HUGE!!
      Mar 2010
      Okinawa, Japan
      With the converter locked up you should be fine with 4.11s, that's the same as 3.08 and 1:1 which I ran for years and never had a problem with on the highway. Another option instead of changing out gears would be to go with a 285/40 tires if you need a little lower cruising rpm.
