      Oct 2013
      which suspension upgrade?
      I have a '98 gmc sierra V6 4.3L and want to lower my truck 2 inches in front and 4 in the back. I have looked at a couple of options that offer lowering kits but would like input as to what works best for handling. Belltech suspension is where I'm leaning towards but still undecided. Recommendations would be appreciated, thanx. I was looking for something with this kind of stance.---->
      Jul 2010
      Sacramento, CA
      That much in the back is gonna require a notched frame. All of the kits are about the same quality, but Ive gotten good customer service from McGaughys in the past, and seen a bunch of these installed with no problems.
      http://www.mcgaughys-suspension.com/...it-part-33137/
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Oct 2013
      Thank you James, that's very helpful.
      Mar 2004
      Mid-Michigan
      The stance in your pic will require more drop then 2/4 will give you. Although 2/4 will improve the handling a bit. I would recommend poly bushings in the front control arms and rear springs and add a rear stab bar.
      What size tire/wheel are you running?
      I did a 4/6 on my '95 with a flip kit in the rear (c-notch required) 2" spindles and 2" springs in the front. Poly bushings throughout and a Hellwig rear bar.
      With 17's and 50 series tires the truck is a slot car. No body lean and good response to steering wheel input. The ride is a bit harsh do to all of the poly but it is worth it in the handling improvement.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Oct 2013
      I still have yet to buy wheels and tires I want to put on my truck. I want the Coys C-55 for my wheels though. I did realize that the drop is going to be more than 2/4. Thank you for your input, I'll look into the poly bushing. Thanx.
      Nomer
