      Salinas, CA. 4.5 MI from the Corkscrew @ Laguna Seca
      Is this "normal"?
      Hi all. After 5 years rebuilding my 68 Camaro in the garage, it's finally engine is fired up and running! I'm really close to having it back on the road again. After starting the engine with the rear wheel on jacks, the rear wheels spin with the Muncie tranny in neutral. I can run the tranny thru the gears no problem. I hit the brakes and the wheels stop and the engine does not bog down. I put in a new Zoom clutch, bellhousing and linkage. So my question is, is this "normal" for the rear wheels to spin with no load? Thanks for your input, TZ
      Central CA USA
      I haven't seen it happen before. The main shaft front end pilots into the input shaft with a roller bearing. I think the rollers have no cage but I may be wrong. There may be something causing drag in the bearing. It might be mis-alignment of the bellhousing pushing the input shaft to one side & causing the bearing to bind.
      You probably need a slightly bigger gap between the pressure plate and clutch disk. What's happening is that when the clutch is depressed, the disk is still dragging against the pressure plate/flywheel. While it may not cause any issues on jackstands, once things heat up, this will cause hard shifting and extra wear on the synchro gears.
      If you have a mechanical clutch linkage, I would slightly lengthen the rod between the z-bar and the clutch fork and see if that makes the problem go away. If you have an inspection window on the bellhousing, you can verify the gap between the clutch disk and pressure plate/flywheel using feeler gauges. For a "normal" organic clutch disk you probably want about .090" gap, but check with Zoom for the exact number.
      Apr 2010
      Jersey Shore
      Do the wheels spin fast like its a direct connection? or just kind of rotating freely? would you stop the wheels with your hand if the engine was just idling?
      The way I read this is that the clutch pedal is released (engaged) with the trans in neutral and it still spins. That sounds like its inside the trans, not the clutch.
      I would expect the wheels to turn in your situation, but not fast like a direct connection. Im no trans expert though...
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
      Dec 2010
      St Louis
      If you turn the input shaft of a Muncie trans out of gear, there is enough drag between the input and output shaft to cause the output to rotate slowly. However, I would be concerned that there's enough drag to rotate driveshaft, diff, and axles. The only possibilities that might cause a lot of drag would be damaged bearings at the front of the output shaft or perhaps a badly misaligned bellhousing.
      I guess it depends on how easy it is to stop the tires from turning.
      May 2011
      Western MA
      Absolutely not a problem based on your description of the symptoms.
      Dave
      Oct 2013
      Grand Rapids, MI
      Based on my experience with my 67 Mustang with a 4 speed toploader (which has a similar design as the Muncie), this is perfectly normal. Mine does the exact same thing if the rear wheels are up in the air with the engine running and the tranny cold. I assume the Muncie you are running has 80w90 gear lube or similar for lubrication, as all old trannys used by my recollection. As garys_68 eludes to, this is nothing more than viscous drag between the input shaft and the output shaft. Contemporary manual transmissions typically don't do this because they typically run light weight oils that don't provide nearly the viscous drag when cold.
      With my Mustang, if it is started up in the winter, I actually need to hold the brakes, rev up the engine a bit before letting out the clutch in neutral. Otherwise, the drag in the tranny will stall the engine. Once the engine starts spinning the tranny and warming up the lube, the amount of viscous drag diminishes.
      Hope this helps. ;-)
