    Results 1 to 15 of 15
      Jul 2013
      Grayslake IL
      Diff Gears Change
      Hey guys I have a question about the differential gears. If I wanted to change 4.11 gears to 3.73 how much would that cost me to take it to a shop and have them do it? Thanks guys
      I always tell others to take the high road, that way there's more room for me on the low road
      Erik Peterson
      1986 Monte Carlo SS Build Thread: https://www.pro-touring.com/threads/...6-Nascarlo-2-0
      Nov 2012
      Sacramento, CA
      Most shops are $200-$250 for labor plus parts. Some are less.
      Where are you ?
      Oct 2012
      Just so you know, this probably doesn't qualify for the "Emergency Room" section. That being said, Ron's post seems to be pretty close. Are you planning on replacing bearings and such while you are in there, or just gears?
      I just had this done and it was almost $600. That included labor, new R&P, and all new bearings.
      Nov 2012
      Sacramento, CA
      I was going to say "around $550" with gear & bearings. But the price depends on brands.
      Jul 2013
      Grayslake IL
      Diff Gears Change
      Im in chicago
      Erik Peterson
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by epeterson View Post
      Im in chicago
      Hmmm. I know several good places across the country, but I don't have any experience with shops in Chicago.
      Quote Originally Posted by Ron Sutton View Post
      To clarify, that was with a Motive Gear gear set and Timken bearing.
      Nov 2012
      Sacramento, CA
      Thanks Andrew,
      Have you driven the motive gear yet? If not, let us know how the sound is. I think many guys are looking for quiet gear sets.
      Oct 2010
      Sacramento, CA
      I was just quoted 200-250 for installing new bearings and ring & pinion with me supplying all of the parts. This is in Sacramento, CA
      Rick - 1969 Camaro - LS1 driven daily
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by ccmc View Post
      Which shop ?
      Sep 2008
      Jacksonville, Florida
      I charge $325-375 labor for a gear change depending on what rear. I will ONLY use Timken US bearings and depending on the rear, the kits run $125-$175. Gears are another story altogether. For daily drivers I strongly recommend OEM gear sets for noise. If it is anything else, I make the customer supply the gear set.
      Lots of guys will do the $200-$250 swap, but they are simply swapping parts, reusing the same shims and hoping for the best. Rear gears have to be setup with the proper tools to get the best longevity and lowest noise possible. This isn't the $50 Raytech pinion depth tool. I have a set that is an OEM tool and VERY accurate for setting pinion depth and backlash/preload, a dial torque wrench for setting turning torque for pinion bearing preload, and a non Chinese dial indicator. I would look for a shop with quality tools that isn't afraid to show you what they use to setup gears.
      Craig Scholl
      CJD Automotive, LLC
      904-400-1802
      www.cjdautomotive.com
      "I own a Mopar, I already know it won't be in stock, won't ship tomorrow, and won't fit without modification."
      Oct 2010
      Sacramento, CA
      West coast differentials
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by sccacuda View Post
      Good advice Craig !
      Nov 2012
      Sacramento, CA
      When we're not doing them ourselves internally at our shop, that is who we use & recommend.
