    Results 1 to 9 of 9
      Connecticut
      LS with carb or SBC
      So I really want to try to keep the classic look of a carb and air cleaner for my 68 camaro project. My question is should i do a ls engine with an intake and carb or just stick with a traditional SBC. my LS option i am looking at is the katech LS hot rod motor. Or my other SBC option i am looking at is the daily driver 427 series from nelson race engines. What do you guys think? does any one have one of these engines?
      thanks
      Paul Krol
      1968 Camaro
      Oct 2012
      British Columbia
      Personally, after already building a SBC, if I could go back I would do the LS. You want a carb now but if you want to change it later you will already have an LS to build upon. I've got a nice SBC but now I'm limited and will end up changing later to an LS.
      Todd
      '14 ZL1, 6 speed and 6.2L of Super Charged Awesome!
      '67 Camaro SS in process. A long, slow, expensive trip...
      How hard can it be...
      Project Obsession
      https://www.pro-touring.com/showthre...ject-Obsession
      If you want the look of the carb, you can do a carb style intake on the LS engine but still use EFI.
      Connecticut
      That is what I was thinking, i have been looking and have not really found many options for that style do you have any recommendations? i thought Mast mad eone but i can not find it on their site.
      Paul Krol
      1968 Camaro
      Washington DC
      Quote Originally Posted by kiwigt View Post
      Those are great options if you want to use a DBW throttle body.
      If you are using a cable throttle body, then you can use any number of other options. Holley makes a couple of manifolds, including the Hi-Ram and a dual quad. Edelbrock makes a single plane intake.
      Jan 2011
      Boston, MA
      Here's my setup. 6.0l LQ9, Edelbrock Vic Jr. LS1 EFI intake (29085), Accufab 4150 TB (DBC). Edelbrock fuel rails, and coil covers.
      Quote Originally Posted by 67rally View Post
      Nice looking setup. What ecm and harness are you using?
      Jan 2011
      Boston, MA
      Quote Originally Posted by alocker View Post
      Thanks. The ECM and harness are from PSI Conversions.
