    Results 1 to 10 of 10
      Aug 2006
      Bleeding done, what else could be a reason?
      Hello guysFirst I will brief you guys with what was initially installed for the hydraulic clutch system, the changes made, and then the issue I am having after the changes done.The car as described in my signature is equipped with LS6 engine that is mated to Tremec 5 speed. The car initially had a wilwood master cylinder (0.75 bore) that was mounted in a location on top of the factory hole in the firewall, which I believe was due to the size of the hydraulic clutch reservoir that did not fit under the Brake master cylinder.With the old set up as mentioned above, the clutch was functioning properly and shifting was smooth.After smoothing the firewall, I decided to go with Keisler Hydraulic Clutch master cylinder which is basically a Wilwood master cylinder with the billet adapter along with pushrod and oil reservoir. I did not get their hydraulic throwout bearing as I arleady had the Mcloed one.I installed the their master cylinder in the specified location as per their instructions in the manual and made sure the pushrod is travelling properly. At first, I had an issue with clutch pedal not coming back up after depressing along with clutch not getting engaged. Then bleeding was done again as per the mechanic. After bleeding completed, the clutch pedal issue was resolved but still the clutch does not get engaged when the engine is running.The mechanic is saying there is no enough pressure from the bearing to push the pressure plate to engage the clutch.The only item I changed was the Wilwood Master cylinder with billet adapter from Keisler. I would really appreciate your advise guys on what else to check for to resolve this freaking clutch issue.
      72 Camaro RS:SOLD
      68 Camaro:
      LS6 Engine,Tremec TKO 600,5 Speed
      Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors
      Aug 2006
      Anyone!!!
      72 Camaro RS:SOLD
      68 Camaro:
      Quote Originally Posted by 72Z/28 View Post
      Anyone!!!
      Send us some details on the setup to [email protected]. Maybe we can help you out.
      Mark
      When you say the clutch is "not engaging" do you actually mean that the clutch is not releasing? It sounds like you your throw our bearing may not be adjusted properly. Did you follow the McLeod instruction to make sure that the face of the bearing is set at the proper distance from the clutch spring fingers?
      Aug 2006
      Hello Andrew
      I mean I can not get it into gear when the pedal is pushed all the way to the floor and the engine is running. The first to photos show the set yup and how high the master cylinder was mounted. The clutch was operating smoothly.
      you can see the master cylinder pushrod passing through a hole made on the firewall.
      After smoothing the firewall, I decided to get the Keisler MC with adopter and their small reservoir and mount the MC on its proper location as shown in the below photo(not mine)
      This is where I started to run into the clutch problems
      72 Camaro RS:SOLD
      68 Camaro:
      Aug 2011
      North Platte,NE
      SO thing were good to go before huh? You want around .100 clutch clearance for one but sounds like trans is in and has been for a while so thats not on the table. That little wilwood has about half the volume of your old one by the looks of it. And it gets bottomed out one to many times the piston seal inside can either get cut or the lip can get flipped backwards from the port inside the bore. Dont be afraid to pull it off and take the rod/piston out and inspect them.
      Quote Originally Posted by 72BBSwinger View Post
      That "little Wilwood" MC has the same volume as the one that he was using, assuming that the piston is the same size. It also has 1.4" of travel. which is more than the 1.1" of travel of the other MC that he was using. In other words, it will work just fine.
      I suspect the problem is in the bleeding or pedal rod adjustment, assuming the TOB is properly spaced from the clutch spring fingers. I prefer .150-.200 of space between the spring fingers and TOB to accommodate clutch wear. Sometimes this is not possible, due to travel limitations of various TOBs on the market.
      Aug 2006
      I suspect the problem is in the bleeding or pedal rod adjustment, assuming the TOB is properly spaced from the clutch spring fingers. I prefer .150-.200 of space between the spring fingers and TOB to accommodate clutch wear. Sometimes this is not possible, due to travel limitations of various TOBs on the market. Andrew
      Andrew I do believe it is a pedal rod adjustment or a bleeding issue because the TOB was properly spaced, otherwised it would not have functioned properly with the old set up either.
      72 Camaro RS:SOLD
      68 Camaro:
      Are there two lines on the McLeaod TOB? Is the line at the top of the TOB the bleeder? Bleeding a clutch s¥stem is pretty straight forward. You can even use the gravity method. Crack open the bleeder and let the fluid start to drip out. Watch the reservoir and keep it full. After about two reservoirs full of fluid having gone through the system, there should be no air left in the system. You can also use the pumping method or any of the power/vacuum methods.
      Also confirm that you are using a 3/4" MC and that your pedal starts off fairly high.
      An alternative scenarios is that your bearing is being over traveled. When this happens, the clutch actually starts to engage again, which gives similar symptoms to the TOB not having enough travel. One way to test this is to jack up the car, put it in 4th gear (engine off obviously), then have someone start to put a twisting force on the driveshaft, while another person is slowly pressing on the clutch pedal. There should be a point where the clutch is released enough that the driveshaft can be turned by hand, in gear. Do that test and note where the pedal is when the driveshaft is able to be spun by hand, and report back.
      Aug 2006
      I really appreciate your time in sharing your knowledge with me. As of the MC, I confirmed that both MCs are 0.75 inch bore and TOB has two lines, bleeder line at the top. I did ensure that MC's pushrod is all the way extended and it is travelling with no kinck.
      I will try to do what you have mentioned but I am wondering if the Spacing of TOB needs to be adjusted again since the old MC as shown in the photo is mounted way away from the firewall with this ugly pushrod.
      I am getting a bit frustrated because the mechanics at the shop are sort of uncooperative and I really doubt they are doing the job properly.
      Anyways I am going to report back in a week or so, hopefully I get it sorted out
      By the way, the above phot was taken long time showing how TOB is spaced when the old MC was installed. The line shown is the bleeder line.
      72 Camaro RS:SOLD
      68 Camaro:
