    Results 1 to 20 of 21
      Oct 2007
      Sound deadner how much? whats priority 1
      So i see some cars with every inch with deadner on it.. but i have read that unessisiary... so whats the scoop? is thier a middle ground? I dont like lots or road noise but i can tolerate some.. its a muscle car after all... what are the priority 1 and priority 2 places I need it?
      Floor Assume priority 1.. what elese? Roof? inside doors?
      67 Camaro In progress
      Jun 2009
      Central FL
      I did roof outer doors floor and I'm going to have to go back and do firewall and trunk.
      Most noticeable will be the floors /firewall.
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
      Feb 2011
      Indpls, IN
      I would also recommend covering all the floor and firewall not just for sound but heat from the engine and exhaust.
      Metro Detroit
      Quote Originally Posted by Jetfixr320 View Post
      2nd that thought. Huge difference!
      Has anybody done a direct comparison? Take a car with nothing other than carpet/underlayment, measure NVH, add sound deadener, then re-measure NVH?
      Does any OEM use a similar product?
      I'm skeptical it does any good at all.
      ​John Parsons
      Jun 2009
      Central FL
      Made my tin can rattle less, however sound deadener is a misnomer, it doesn't really stop sound it makes the car feel and sound more solid.
      Most OEM's use that jute stuff because it's cheaper (and thicker/heavier) than foam deadener (such as the stuff Second Skin sells).
      Dan
      1968 Camaro v2
      Waterloo, Ia
      I'm going to do my GTO this spring. It has nothing in it right now but carpet and some white fuzzy stuffing above in the headliner. Is there an easy or standard way to measure NVH? I could probably do a little test if it's not too difficult
      -Nick
      -1967 GTO I drive and race
      -Build threads:
      Oct 2012
      I know with stereo's it is very important. When the subwoofer "hits" it increases the pressure in the vehicle. The panels all flex when this happens, some more than others, and when the pressure is decreased it causes the panel to reverberate (?) which basically turns your panel into a speaker. The panels vibrations will cause small sound waves that interfere with your stereo's sound, basically canceling any out that are the same frequency, messing up your sound quality.
      As far as road noise, I noticed a slight decrease. I've heard that the thick mat type, not the "tar" type, sound deadener is better at reducing NVH. However, it doesn't decrease heat or stop panel vibrations like the "tar" ones do. For the luxury feel, you are supposed to have both. This would add quite a bit of weight, but it is the ideal for a quiet cabin.
      A simple showing of how well it works is to tap on a roof or large panel after you deaden it. If you tap without, it almost rings from vibration. Afterwards, its a simple thud sound. Of course, this isn't scientific, but it does show how it stops vibration. However, your road noise isn't always from the panel vibration.
      Supposedly, with the tar type, you don't have to cover the entire panel, just enough to stop the ringing. Car stereo shops demonstrate this by putting a small (less than a dime) size piece of deadener on a bell, similar to a "door hop" bell, and then let you ring the bell. It just thuds, even though it only has probably 5-10% of it's surface area covered.
      I hope this helps somewhat, I am no expert but I have read up quite a bit since on of my other hobbys is large car stereos. The serious sound competitors go as far as filling in panel gaps with cement to stop unintended noise. These are the DB drag vehicles, and that is their sole purpose. Any flexing works against that purpose, so they go to the extreme.
      Oct 2005
      Toronto
      Like others mentioned here I too question the coverage and effect.... Lately many of us are fighting weight in our builds and this stuff weighs a ton (and frankly for my part I question it's impact)...
      Personally I will be building without the Dyna-Mat in my next ride and look to other options that include treating the exhaust system front to back with Jet-Hot coatings and a material I am investigating currently that is very interesting so far....
      Carbon Kustoms Limited
      A.K.A. Albert from Toronto
      I built my last car (the Tommy Camaro) without any Dynamat. Just a high quality carpet and mat. The car is quiet, comfortable, and met the customer's expectations. Admittedly the car is just a cruiser (LS3/T56/Quadralink) with a minimal stereo, but some passengers were shocked when I told them the car had no sound deadener or heat insulation other than carpet.
      The car before that was also a 69 Camaro, and it had Dynamat everywhere. I still have remnants of the tar on some of my clothes. That car was quiet and comfortable too. I don't think the Dynamat makes it worse... just not convinced it makes it any better.
      I know the "tap" test, etc. and I suppose the Dynamat would help in a hail storm, but I remain skeptical it has any real-world application, except maybe with high-end stereo systems.
      Great discussion. Let's hear more, please!
      ​John Parsons
      I think everyone should read the info on this site and then discuss:
      http://www.sounddeadenershowdown.com
      Oct 2007
      Thanks for the link... will defiantly read twice.... also thanks for the opinions... first i have heard that it makes no difference.. but weight is defiantly a concern of mine.. I have rhino linered floor on the bottom and would wrap the exhaust or coat it without reservation.
      Milwaukee, WI USA
      Dynamat recommends that you do things in the following order;
      Doors first, then Trunk, Rear Deck, Floors, Roof, Hood, and then Fenders.
      I'm not sure if I agree, but take it for what it's worth.
      IMO; the order would be Doors first, then Floors, Rear Deck, Roof, Trunk, Hood, and then Fenders.
      1969 Camaro SS, 350(NOM), M21, 12 Bolt Posi, 01B (Jan 69) LOS Build
      Jul 2013
      St Louis
      I know this thread is old but I had a question.
      When applying in or on doors do you apply it on the outside door skin or the inside frame where the door panel fastens. Seems like the inside frame would be best but if you ever have to get to you window regulator or something you're screwed. Ive done about every inch of my car except the doors. I have to get in there to replace the rollers for my windows before spring and was thinking of adding it while Im in there.
      So outside door skin or inside frame?
      Pontiac Powered 72 GTO
      Feb 2013
      Lynchburg, Va.
      Quote Originally Posted by Gratefuldiver View Post
      Inside of the door skin you want vibration control, such as Peel and Seal or Dynamat. Asphalt or butyl based products which stop drumming in the sheet metal. Sound deadner goes behind the door panel.
      Dec 2010
      Fredericksburg, VA.
      I did a couple of 4" x18" strips of dyanmat on the inside of the outer door skin and then covered the inner frame under the interior door panel.
      If you do a search for "Car audio sound deadening material" the audio crowd has a lot of good experience with sound deadning vehicles. Of course their goal is to make the stereo sound better but keeping the interior noise down is the same issue.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Oct 2013
      H-Town, TX
      It made a huge improvement on the doors of my 69 Charger. Well worth it.
      I've never driven the car with the windows up so can't really tell you how quiet it is.
      Oct 2014
      Cañon City,CO
      I have a welded in rear firewall in my 68 Mustang for about 3 years I drove it around and it was very loud inside. Conversation was just below a yell. I made a trip to California from Texas in it and within a mile of home I was trying to figure out why it was so quite. The trunk was stuffed. I got to Ca , unloaded the trunk, it was again loud as heck. When I got home I found the above link. I cut 8 2" by 12" strips of Dyna Mat and stuck them in a V pattern to the rear firewall and inside the inner back seat side panels plus a few more on the rear floor above the axle. I think I have about 10lbs total in tar. It is now possible to talk in the car.
      BTW I have 3" Magnaflow exhaust exiting below the bumper.
      Feb 2011
      dallas, tx
      i cut all of my dynamat in strips and made applied it on all different angles and lengths. I didn't feel the need to cover every single inch. Another thing that i did was dynalined the removable inner panels. This will help keep heat out. Doing the strips the way i did also I'm then still able to remove and work on anything on my car without removing the dynamat.
      Feb 2009
      Laramie, WY
      This was along ago. At some stereo shops, dynamat had a display that had two pieces of metal, one with a small piece of dynamat on it. the other didn't have anything. You could hit the pieces with a small attached hammer. The deadened one didn't have the metallic ring. this was dampened by a small piece of Dynamat. To dampen vibrations you do not need to completely cover an area. In my 2002 USACi Sound Quality world champion. I did not dampen the whole door. ( 4 of them) or the trunk lid. I used pieces about 4" square. While some think it looks cool to have the deadener logo all over the floor, roof, doors, etc of a vehicle. it is over kill. For heat you may have to cover a larger area. but only apply to areas that need it. You don't have to put heat shield on the top of your trans tunnel if your running side pipes.
      Tim
      1971 Buick Sportwagon pro-touring project. Buick 455 TH350, SPC front suspension, UMI rear suspension, KYB shocks, Slowly getting there.
      1985 Ford Crown Victoria 2 door next project.
