    Page 2 of 4 FirstFirst 1 2 3 4 LastLast
    Results 21 to 40 of 69
    Thread: 61' Buick
    1. #21
      Feb 2012
      SW, Michigan
      Made a little progress on a quarter panel patch today.
      Long way to go but happy with the first contour line.
    2. #22
      Jul 2012
      white or red interior sure look great on these cars. light blue or platinum with a white top.
      Quote Originally Posted by Auto Rod Technologies View Post
      The downside to these buicks is that body panels ar tough to find. so time to break out the metal equipment and tig welder. lol..
      Plans as of now are upgraded brakes, bigger wheels, suspension mods which have yet to be decided on, but lowering and air have both been discussed, I believe we are going air though.
      Sounds like black body, I think he's keeping the teal interior but I think it's a mis match, one or the other should probably be changed. what are your thoughts??
      Upgrading trans to probably a 700R4, not sure on motor, I have not seen what he had in it or discussed any plans to change.
      Right now we are focusing on getting the body patches done and then on to the next stage.
      Probably a vintage air set-up.
      I kind of want to get it off of the rotisserie as well, because I have a impala resto project that may end up on that.
      As of now that is all that is planned, but we know how these projects snowball.
    3. #23
      Apr 2011
      What a great project, love it.
    4. #24
      Aug 2008
      jacksonville,fl
      I'm sure more people will take interest here once you get past rust replacement & start with the cool stuff, but I always find pictures of metal fab inspiring to me. I don't always need actual instruction for a lot of things, just pictures for inspiration.
    5. #25
      Cartersville, GA
      We recently did some work on a '59 Buick LeSabre...love the old Buicks!
      Joe Hinds
    6. #26
      Tennessee
      Nice progress so far.
    7. #27
      Aug 2005
      Waterloo Ontario
      keep us updated
    8. #28
      Feb 2012
      SW, Michigan
      Struggling with this quarter panel patch, trying to do it in one piece and also easy to reproduce.
      I'm leaning towards press form or more press dies at this point.
      stay tuned.. lol.
    9. #29
      Nov 2011
      College Station, TX
      I don't know what his plans are with the axle or drive train as of yet, but we may be doing some cutting for air ride suspension before it's over with, making any axle fit at that point wouldn't be much of a issue.
      As far as trans I believe the ultimate goal is a 700r
      He's thinking of the tiny Special/Skylark that's built off of the Corvair floorpan. The full sizes share the basic configuration with the 63-70 Riviera but have a different steering box arrangement and some other differences. Other than custom fabricating an oil pan, you're going to be hard pressed to fit anything into the rear steer, front crossmember engine bay other than a Nailhead or a Big Block Buick with a Riviera pan. You can do a 300/340/350 with an early 300 oil pan but it's some work. I custom fabed my Buick V6 pan out of an early 300 pan V8 and a 80's Regal V6 pan.
      TH700R4 can be put behind a BBB, I did it with my 70 Riviera. Just need a BOP adapter and a custom driveshaft. Be aware these cars are 2 piece shafts through the X-frame and the center carrier bearing can be fragile.
      Sorry for the old post but I'm interested in seeing how things are going as 61 "pointy fender" Buicks are second only to the 63-65 Rivieras in my list of favorite cars.
      Central TEXAS Sleeper
      Experimental Physicist
      '64 Riviera T-type: 4.1L Buick Turbo6, 4L80E, L67 OBDII SEFI swap
      ROA# 9790
    10. #30
      Feb 2012
      SW, Michigan
      He's now talking about a 400 trans with gear venders over drive unit.
    11. #31
      Oct 2012
      Kennewick, WA
      I envy your metal working ability. It makes me thankful to live where I do, rust is not a huge issue when you live in a place that has less than 10" of precip per year.
      Quote Originally Posted by CTX-SLPR View Post
      Couldn't agree more, those early Rivs are beautiful cars! I really like the not so common cars which is one of the reasons I parted ways with my 68 GTO. I have a friend selling a nice little 62 Olds Jetfire and if I didn't have my Maverick I'd be working a deal with him on it. Real clean car that would be a great foundation for a build.
    12. #32
      Nov 2011
      College Station, TX
      I need to make a major correction!!! The steering box differences makes the 61's the only combo of X-frame and Rear Sump oil pan for a Full Sized Buick. That opens up the engine choices a lot (though it would pain me to see another chevy powered Buick). Going to the TH400 helps since nailhead and BBB both were backed by them as were the SBB and V6's. However fitting that GV with the X-frame still might be a problem.
      ROA# 9790
    13. #33
      Oct 2012
      Hesperia, CA
      Just discovered this thread. Like the work, glad to see another Buick being built. Subscribed.
    14. #34
      Feb 2012
      SW, Michigan
      [QUOTE=RMMiller;950615]I envy your metal working ability. It makes me thankful to live where I do, rust is not a huge issue when you live in a place that has less than 10" of precip per year.
      Around here were luck to get anything with any metal left on it.. lmao.. I enjoy doing some of the rougher metal repair work, better than seeing these cars get crushed. On a temporary break on this car, but it's good timing as i'm getting some more tooling to make it easier to make these quarter panels.
    15. #35
      Feb 2012
      SW, Michigan
      I'm pretty sure he is in the process of getting the original motor rebuilt for it right now. We're pretty busy here right now so him focusing on the motor is a good thing, plus then it will be ready when we get to it, he is planning on getting frame powder coated along with all of the suspension components so it should all look pretty clean when finished up.
    16. #36
      Feb 2012
      SW, Michigan
      I think he's been looking at wheel choices to. not sure what he is going to pick.. anxious to see.
    17. #37
      Feb 2012
      SW, Michigan
      This thread has been sleeping for a while, time to update it with a few pics, started putting some more effort into those quarter panels.
      Started last week, here's some pics.
      These pics are of the rear body mount section of the body, made some new mounts to weld in.
    18. #38
      Feb 2012
      SW, Michigan
      Now for some quarter panel pictures. Want to dive in a little deeper into metal work, and perhaps cut back a little on how far I get into these projects..
      Want to focus on metal work and paint/body work in the future, a little less mechanical..
    19. #39
      Oct 2012
      Country Flag: Australia
      Man... That takes some serious skill.
      I would love to learn how to do that stuff.. but I ain't smart enough.
      All I am good at is the driving side of things. lol.
    20. #40
      Feb 2012
      SW, Michigan
      It's been a little bit of a learning curve for me but i'm starting to get the hang of it thanks to a class I took from Wray Schelin..
      http://www.proshaper.com/
      He's a great teacher, and very knowledgeable on metal..
      It helps that I knew I wanted to go in this direction with work so I've been buying and building equipment over the last few years, I think i'm off to a good start now in progressing the shop into doing more sheet metal work..
      I have spent a little bit of time on this today, I have the back section clamped into place, Almost ready to weld in but I need to do some final fitment work.. Maybe i'll post up a pic tomorrow.
