    Page 1 of 4 1 2 3 4 LastLast
    Results 1 to 20 of 62
      Vinny's 68 camaro Shocked runs 9's
      guys, its been awhile but vinnys 68 camaro shocked, just went 9.98 at 138.47 in the 1/4 mile at atco drag way. Pretty unreal for a pro touring street car.
      We will post video later of the run. heres a pic and stats
      1.53 60 ft
      [email protected] in the 8th
      [email protected] in the 1/4 mile
      This is on a 100 shot, his progressive controller died last week and he is on a wot switch, he spins coming out of hole with nx armed, so on his 9.98 run he armed it just after launch,lol Once new controller comes in he will run it on 200 shot but dial it in over a few seconds, should run 9.70s easy.
      USA
      Holy Crap !!!
      Jeff Tate
      U.S.A.
      Central Valley Ca.
      How fast w/out laughing gas? ... I wish I had your 60' times...
      1969 Camaro..getting closer to being done..I think
      1994 Camaro... Future N.A.S.A racer... maybe
      Victory Circle South West Tour race car (SCCA)
      2006 SS Trailbrazer (Wifes)
      2007 LTZ Chev Silverado 4x4 with the sports suspension package
      Greg is my other name...
      Web page..
      http://www.youtube.com/user/itlbtu?feature=mhee
      charleston, SC
      NIce tire tote!
      Robert's 1969 Camaro - 2002 LS1/T56, 10pt cage, Global West Stage III front suspension, HTH truck arm rear suspension, Sprint Cup 9" full-floating rear end, Fikse Mach V 17" up front 18" in the back and still working on it...
      Mountain View, CA
      Video?
      I want to hear that thing on the pipe with split-second paddle shifts!!!
      True T.
      My blog
      Oct 2005
      Orlando, Fl
      Nice runs.
      Looks like the wheel/tire combo was swapped. Was the suspension still PT? Adjusted the shocks, removed the front sway bar?
      Michael Barnes
      71 Chevelle - LS1/T56 swap - On the Street!!
      Jan 2003
      Arizona
      That's right!
      Uh huh.
      Yup.
      Correct
      ________________
      Steve Chryssos
      Jan 2003
      Arizona
      Quote Originally Posted by Damn True View Post
      Video?
      Than new Bowler 4L80E-1000 shifts crazy fast. And never harsh.
      ________________
      Steve Chryssos
      Maryland
      Way to go Vinn,I knew that car had it in there. Ron
      Ron Schwarz
      Jan 2003
      Arizona
      Quote Originally Posted by stealth71 View Post
      Nice runs.
      Sway bar remains attached. The car has air ride Technologies suspension so the only hardware that gets turned are lug nuts. Every other component remains exactly the same as the Auto-X, street or road course set-up. Process is as follows:
      -Swap Wheels/Tires and wheel spacers.
      -Raise the rear to accommodate taller rear tires.
      -Rebound of front air ride Shockwave adjusted to dead soft.
      -Pre-load right rear bag as needed.
      Hopefully, Vinnie can resist the 200 shot jets. Before this outing, peak oil pressure was down near 45 psi cold. You can only send a 496 big block up to 7000 rpm so many times before the bearings need freshening......
      ________________
      Steve Chryssos
      Henderson,NV
      Wow....that is impressive! Way to go guys. My 489 has always had 50 psi max cold. It was built that way though. What's getting upgraded in the motor while it's apart?
      Todd
      Jan 2003
      Arizona
      Shhh.... Please don't say "apart". It's probably better to say "disassembled" until he makes it back to the shop. The rest of the engine is rock solid. It just needs to be freshened.
      ________________
      Steve Chryssos
      Nice times! I love this car and it sounds so sweet..
      Jul 2008
      ATL
      wow congrats!
      that is killer - what tire size, rear gear, transmission and horsepower are your running?
      HPDE is the greatest thing since sliced bread.
      So much to learn......so much $$ to do so lol
      San Jose, CA
      Quote Originally Posted by Vegas69 View Post
      Holy cr@p! That's BAD@$$! That's a sweet quarter mile for any car, but especially for a Pro-Touring car. I wonder if that's a record for a Pro-Touring car? Congratulations!
      I wonder what's going wrong with the pressure. My 433 is like 90 psi max cold. A buddy had 45 PSI too, but his was like that from the get-go. He didn't notice during assembly, but a main cap nut was a tiny bit too big and was keeping the oil pump from seating against the cap surface.
      @Camaro.Family Camaros
      1986 #IROCdaily - Stock IROC
      yeah its been 3 years of abuse, so its time to check valve springs, mains and rods etc as it is more race motor then street motor.
      Theres nothing like hearing this thing at 7200 rpm thru the 3 inch oval exhaust and spin tech mufflers.
      496ci
      10.9-1
      afr cnc heads
      ultradyne solid roller .710 lift, 262/266 [email protected] on a 108
      scat crank and h beam rods, internally balanced, wiseco pistons
      .040 quench
      dart single plane with pro systems hp1000
      bowler 4l80e killer tranny with the twist machine paddle shifter making it happen.
      it has a reg pump not hv. bearings are calico coated and were all sized at .0025
      pressure is 45 cold at idle, and goes up to 55-60 at rpm which is about what it has always done, maybe 5-10 psi lower , its way cheaper and easier to freshen it then rebuild it.
      engine hp is 680-700 flywheel, 530-550 rwhp
      runs 10.60 flat at 131-132 on motor.
      Mountain View, CA
      Quote Originally Posted by hotrdblder View Post
      ....which is why I requested video of the pass....dammit man I need to live vicariously through those with finished cars....motivation wanning...frustration building.........True sad........
      True T.
      My blog
      Henderson,NV
      Sounds like plenty of pressure to me. Hot oil pressure at idle is where you will see your difference if you have bearing wear. Pretty radical setup, better safe than sorry I agree....
      Todd
      Sandy, OR
      wow that's sweet lets see a video
