    Results 21 to 40 of 46
    1. #21
      Oct 2007
      ridgefield ct
      yeah, that's a load of crap. the guarantee doesn't say anything about THEIR problems. i think i'll have to talk to my brother about the other place. he does a lot of business with the toolwarehouse, but maybe he'll the tooldiscounter more.
      work in progress--for the next 10 years.
      1987 monte carlo ss 383ci, 9.7:1, xe274 cam, vortec heads, 200r4, 3.73 posi.
    2. #22
      Southern Indiana
      ok
      Quote Originally Posted by The WidowMaker View Post
      ive been intending on using a single 37* flare for both the brake and fuel system on my car. i had initally heard that this wasnt a problem as long as the proper tube nuts were used and the fittings were converted pack to pipe thread at all the inlet/outlets. after reading the above, i decided to do a little more reading.
      the consensus was that double flaring was three fold. first, it provided a stronger flare in weaker tubing (aluminum), it allowed it to crush and therefore seal, and it folded the outside seam over, thus putting it on the inside and out of the way of the seal. seamed tubing that is single flared WILL leak. some success has been had with using the soft metal washers in the joints to act as the double flare does.
      also, i looked into the pressure ratings, and although this is only one site, it says that 3/16" stainless tubing with tube nuts is rated to 5000lbs. they state a 4:1 safety factor, so im not sure if that puts it at 20,000 psi, or the more likely 1,250 psi.
      heres the link http://www.sealexcel.com/37degree-fl...ressure-rating
      hopefully somebody will have access to accurate numbers from a published manual.
      my plan was to buy the 71480 which only includes 37* mandrels.
      Tim
      If you can find a distributor that sells the addon kit for 37 degree mandrels and such , I am looking for the 37 degree stuff to add to it.
      Oh and if you just happen to snap the 3/16 push die(the one with the pin in it just find snap on dealer they can warranty or just call mastercool. Very nice people.
      But no sales to individuals.
      This kit is THE BOMB.
    3. #23
      Southern Indiana
      Mastercool sets
      I believe the 71480 is the large set doing everything EXCEPT 37 degree flares.
      The 71098 kit is the 37 Degree add-on kit going for between $61.99 here:
      http://www.automotivetoolsonline.com...8_p_12131.html
      http://www.etooldirect.com/manufactu...5QodDUfzbQ&p=4
      $69.99
      http://www.tooldiscounter.com/ItemDi...ookup=MAS71098
      $69.96
      figure it with all these parts you can flare the world!
    4. #24
      Dec 2007
      Carlsbad, Ca
      monzaracer - the 71480 kit ONLY does 37* stuff. its about 240 for the kit, so if you dont intend on doing 45*, its the perfect kit.
      Tim
      Tim
      Build Thread Link
    5. #25
      Dunwoody, GA
      37* is AN and 45* is all the inverted flare stuff correct?
      Man I need to get my hands on one of these kits. I hate flaring with those hand powered twist ones.
      Trey
      ~ Jon Hammond
    6. #26
      So. Cal.
      Quote Originally Posted by WS6 View Post
      37* is not just AN. AN is the standard that describes what tolerances the fittings are to have. For automotive the standard for 37* is JIC. So you can get the 37* fittings in either AN standards or JIC standards.
      As for the hydraulic flaring tool the 71475 kit does all the brake lines that are common and the add on kit 71098 does the 37* stuff. Thats the route I would go. The 71480 is just the 71098 with the pump. So you would be lacking the ability to do brake lines.
      You can get the 71475 and 71098 delivered for about $360 and you will have all the flares covered. JR
    7. #27
      Southern Indiana
      ooppss thanks for correction guys got in hurry and hit wrong link i guess but adding on the 71098 would make kit complete.
      but since I found big jump box for work I wont be adding it till next month or month after.
      sometimes my "toy" buying gets the best of my extra cash even if I am a tech!
    8. #28
      Dec 2007
      Carlsbad, Ca
      not sure i agree. there are plenty of guys doing brake lines with the 37* fittings (tube nuts) and seamless stainless. correct me if i'm wrong.
      Tim
      Build Thread Link
    9. #29
      Keller, Texas
      I have the main kit and have just flared things normally then broke out my cheapie Summit 37 degree kit and wnet over the flare again to massage it to 37 degree (or at least close enough). Haven't had a problem with it so far. I saw they had the 37 degree cone available seperately, but for $60 the add on kit is worth looking into for sure.
      Greg
      1970 challenger convert-in process
      1970 barracuda-driver
    10. #30
      Quote Originally Posted by MonzaRacer View Post
      As for the Mastercool hydralic flaring tool, BUY ONE!!!!!!!!!!!!!!!!
      You will NEVER GO BACK unless you have too.
      It will also if its big kit, give you the ability to do ISO or "Bubble" flare, GM old school FI fuel filter flare thate uses the orings and FI style filter. And it will give you the ability to make the push connect flar for say Ford fuel filters too and lots of stuff like buying the 37 degree adapters give you a way to to the AN flare too.
      I spend $468 on snap on truck and its best nearly $500 investment I have made yet.
      I even use the older GM fuel line flare to put a rib on fuel lines and tranny cooler lines when using hose clamps, the hose will never slide off unless it gets a LOT of pressure.
      totally agree, bought mine off the Snap-ON truck and it is TRICK!!
    11. #31
      So. Cal.
      Thats interesting. I havent heard of it but I imagine you could use 37* for brake lines.
      But personally I like to stay with the industry standard when its available. And seeing how the standard is 45* and there are plenty of off the shelf products for 45* brake systems thats the way to go.
      Not to mention many of the parts that arent tubing, like master cylinders, proportioning valves and wheel cylinders are 45* it kinda make sense to stick with the standard. I dont see any advantages of using a 37* flare for brake systems. JR
    12. #32
      Dec 2007
      Carlsbad, Ca
      i havent got that far (brake plumbing) on this car, and the last one was done in all 45*. but, if i remeber correctly, all the joints are either btwn lines, or threaded into something (distribution block, p valve.....). therefore all you need is a tube adapter on the end of your line (you would anyways), and then a conversion from 37 to whatever thread.
      the main argument ive heard for the 37* is just consistency throughout the system. brake and fuel would all be the same, look the same, and go togther the same. plus you save on tools.
      Tim
      Tim
      Build Thread Link
    13. #33
      Newbury Park, CA
      Quote Originally Posted by JRouche View Post
      Brake lines can be done with 37* flares but the fittings must also be 37*. No mixing and matching of SAE and AN.
      As for the question of 37* vs 45*, if the system is close to stock where many of the stock components are used, then 45* may be the best option. For full-on custom systems AN is far easier due to the variety of available fittings and the ease of mounting them. If a stock appearance is needed then AN is not the way to go. Most aftermarket adjustable proportioning valves have 1/8" NPT fittings so fitting either 37* or 45* is the same. Just about all master cylinders and OE-type proportioning valves can be converted to 37* using by means of an adapter made by Earl's, Aeroquip, Russell, the local hydraulics store, etc.
      The conical AN sealing washers work very well. I have used them in several applications, including high-pressure hydraulic systems, with good success.
    14. #34
      Dec 2007
      Carlsbad, Ca
      carl, are you using the washers for all the fittings? thats what i thought they were intended for, but some have just used them when a fitting leaked.
      Tim
      Tim
      Build Thread Link
    15. #35
      Newbury Park, CA
      Only when the fitting leaks.
    16. #36
      Jun 2006
      Halden, Norway, Europe
      Anyone know if the Mastercool tool can be repaired when the hydraulic part has a leak?
    17. #37
      Orlando, Fl
      Quote Originally Posted by 64Chevelle View Post
      Yup, just had mine rebuilt!
      Nick DiPrenda
    18. #38
      Central CA USA
      I have the Mastercool tool and love it too! The only fault with it is when doing the smallest lines, the blocks that hold the tube are not on center with the cylinder. This may cause a misshaped flare from time to time. I made a piece of shim stock out of .040" aluminum and put it opposite the screw that clamps the blocks together. It upped my success rate double flairing the small lines to something like 99%.
      David
    19. #39
      Oct 2007
      ridgefield ct
      Quote Originally Posted by dipren443 View Post
      how much did that cost? and did mastercool do it directly or was this through snap on, mac etc?
    20. #40
      May 2000
      Where do you get these sealing washers?
