    Results 1 to 8 of 8
      Oct 2007
      ls3 hot cammed gmpp 495
      getting conflicting data.. looking for opinions..
      Using Mobile 1.. 0-40 or 5-30 full synthetic which is ideal for street driving in a 4 season location *will never see winter but may be started in a cold garage
      67 Camaro In progress
      Beach Park IL
      Are you asking for oil opinions? I thought that was like religion and politics. Anyways, I put Driven LS30 in everything LS so 5-30 is my answer. Street drive, track days, autocross in nearly all temps.
      Donny
      Mar 2022
      Florida
      You won't find a big difference between the two. Oil is been debated to death in just about every car forum on the planet. If the motor is a typical build and not "loose" (higher clearance in the crankshaft bearings) a 10 W40 will work fine. If you put it in and find the car is running higher or lower than normal oil pressure (clearance or pump dependent), then adjust the weight to fit the motor. I happen to have a large clearance motor (It was originally set up for boost so I believe the previous owner wanted more oil cushion) so I have to run a 20 w50 weight oil. I live in Florida so I never see cold weather. That works for me. Just put something in it, run it and see if you like the pressure.
      Apr 2016
      Most LS are run on 5/30, but can run 10/30 or 10/40 likely with the same result.
      Oct 2007
      related any differance between Mobile 1 full synthetic its way cheaper .. I read its lower cost to compete but is it crap is my question
      Santa Barbara, Ca
      For what it’s worth, Chevrolet Performance recommends Mobil 1 15w50 for my LS427/570 (cammed wet sump LS7) engine. Maybe the LS3 motors are different, but that’s what they say to run in mine.
      Andy
      1967 Camaro RS
      Magnacharged LS1/T56
      543 rwhp, 516 rwtq
      Sold
      1968 Firebird
      LS427/570 and T56 Magnum
      Feb 2011
      dallas, tx
      5w30 or ls30
      Oct 2007
      Quote Originally Posted by streetk14 View Post
      Yes defiantly ls 7 dry sump has higher oil pressure ..
