    Results 1 to 16 of 16
      VA
      1980 LS2 powered Trans Am
      Pro touring classic!
      Beginning with the excellent second generation f-body foundation and a rare "X" code Turbo Trans Am Pace Car, this vehicle received thousands of dollars in modern technology to turn it into a modern day stealth machine.
      • Low mileage, all aluminum 6.0L V8 LS2 and 4L65E automatic transmission with overdrive from a 2005 GTO.
      • Moser 12 bolt rear end with 3:73 gears and Eaton posi.
      • Full Ridetech suspension consisting of improved geometry A-arms, 4-link rear, and single adjustable coilover shocks allow the driver to change the ride to meet the demands of the road.
      • Camaro fuel module (2010 Camaro SS) inside a Rick's stainless fuel tank easily handles the demands of the driver and motor with a proven performance EFI tune.
      • All stainless exhaust from the headers to the tailpipes.
      • Aftermarket gauges
      • Air conditioning, or heat, will keep you comfortable.
      $25,000 OBO
      Below link has additional information and receipts, pictures, and videos.
      Yorktown, Virginia
      https://www.ebay.com/itm/23289870664...84.m1555.l2649
      Last edited by Larry Callahan; 08-30-2018 at 05:54 AM. Reason: Requested a price change
      May 2015
      Island Lake, IL
      That is awesome...nice!
      VA
      Quote Originally Posted by F-Body International View Post
      Thank you, will make someone very happy!
      VA
      Moved video links and additional information over from eBay listing so they are available here:
      Video walk around: https://youtu.be/3DESdUuQr6k
      Video start up: https://youtu.be/FMGG5wi0EL8
      Video drive1: https://youtu.be/nWw6BvoaUEY
      Video drive2: https://youtu.be/d_vnn2Vk_Gs
      Video drive3: https://youtu.be/3BrXPi7Yob0
      Video drive4: https://youtu.be/_EJEX9LRL6o
      Video "drive1" and "drive4" you can hear the engine and exhaust.
      • Interior is mostly original and in very good condition. The white plastic interior pieces show some yellowing. Floor, trunk, & other panels are original. The underside was sprayed with chassis black about 2 years ago. It could be resprayed but depends on the amount one would drive.
      • Exterior is a repaint with new decals. Based on no orange peel and minimal chips, the car shows very well.
      • Most everything that I can think of has been gone through recently, from the air/heat to the brakes.
      • Drivetrain had about 41K on it when installed but I don't have documents. New gauges were installed at the same time & show 3,254 miles. No leaks or drips.
      • Discrepancies: + headliner is drooping at the t top crossbar. + passenger side visor absent. + if shipping the car, would recommend installing t top seals. The current seals appear original and will leak if wet (I avoid rainy days and spraying water on it directly). + passenger seatbelt currently won't retract.
      • 2005 GTO LS2 is 6.0L 400hp motor. Drivetrain electronics consist of 411 ECM/24X reluctor, correct for a 2005 LS2. Wiring harness is standalone, 3 wire hookup. Thus service is essentially 2005 GTO. ECM is located below radio & behind the console. No dyno sheet, should easily be 370+hp at the wheels.
      • Receipts do not show purchase of drivetrain and other related parts, vehicle, & expensive items like the fuel tank.
      • Exhaust is stainless headers, 3" stainless tubing, & magna flow mufflers.
      • Pro touring f body chassis bracing, subframe connectors & triangulated g braces in the front. Doors do not drop.
      VA
      VA
      after much thought, price reduction: $25,000
      Nov 2014
      Las Vegas, NV
      Just a suggestion, but a good chunk of the car's value is tied up in the aftermarket suspension, yet you have no pics of it in the listing. I would add more pictures of the suspension to help justify the price. Just my 2 cents.
      VA
      Quote Originally Posted by 2ndGenJunkie View Post
      Thanks, if anyone would like to inspect the car in person, lift is available.
Size:  196.1 KBName:  IMG_1689_zpsz21wp6tn.JPG
Size:  200.8 KBName:  IMG_1691_zpskrpkvriq.JPG
Size:  196.4 KBName:  IMG_1690_zpsup1gyscj.JPG
      VA
      no longer on eBay, brought over some additional pictures. If you're in the market for a pro-touring car, look no further.
Size:  166.6 KBName:  IMG_0370.jpg
      VA
      Ttt
      Jan 2015
      Missouri
      Still have this?
      VA
      Yes.
      VA
      Spring has arrived for most regions of the world.
      Out of winter storage and actively on market. Don’t miss the early opportunity to take the T tops off and have the wind blow through your feathered hair... or toupee..
      non environmental friendly hair spray, mirrored shades, half shirt, stone washed denim extra but this TA walks a modern day swagger underneath it all.
      Era correct soundtrack still included in CD format for easy sharing among copy right infringement conscious millinneals.
      Nov 2014
      Las Vegas, NV
      Quote Originally Posted by ErikSOCAL View Post
      Good luck with the sale!
      VA
      Under deposit - sale pending
      May 2019
      did this car sell?
