Results 1 to 7 of 7
Thread: Used 9" Rear Value/For sale
01-28-2018 #1
- Jul 2017
- 166
I'm going to be swapping out my rear suspension for a 4-link and new complete 9" so I'm looking to see what my current 9" might be worth. I tried the marketplace section to get an idea of what its worth but no replies.
The 68 camaro was purchased with a 9" with an unknown gear, seems to be around 3:50 form what I can tell. Has the spring perches moved to accommodate the leaf springs and is a little narrowed compare to stock length. Looking to see what this is worth? It will come included with 11" single piston disc brakes, drilled and slotted rottors, multi-leaf springs, traction bars brake hoses and ebrake cable. Has 28 spline ford bolt pattern axels (1.25" wheel adapters included for GM bolt pattern). Total overall mounting with is 56-5/8" (51" flange to flange), add 2.5" for the wheel adapters unless you swap axles. That's about all I know about the rear.
This is for sale, just dont know a price. Open to offers, located in SW Houston.
01-28-2018 #2
