    Results 1 to 10 of 10
      Jun 2014
      VADER 69 Camaro LS3
      Project is about 8 months underway and inching closer and closer to paint. Special thanks to Jeff Gregory owner of GB Customs in Corbin, KY for handling the majority of the work on this project. Paul Atkins Interior Shop will be taking care of finishing the interior for me. Thanks to Eric Brockmeyer for the renderings and input on the interior design and materials.
      Long story short this was a very good car prior to this stereo upgrade. I purchased some high end speakers and headunit last November/December after mulling the idea of just selling the car to begin with. I wasn't driving it much but eventually decided to add a better sound system and keep it. From there I decided to upgrade the suspension and then decided to modernize the interior while maintaining some of the characteristics of the 69 that I liked. After several weeks of going back and forth and researching other add-on improvements I could swing for, I had quickly designed a major overhaul and a project much larger than I could handle alone.
      Originally, the car was going to go to East Tennessee for the interior so I needed or at least preferred a shop close by to handle the rest of the work. I found Jeff and the rest is history.
      Upgrades
      Body:
      Anvil Carbon Fiber Front lower valence with light buckets, notch front and rear spoilers, radiator closeout panel, firewall cover, inner fenders
      Fesler flush mount glass
      2nd gen side mirrors
      LED lights all around
      Fesler Smoked black anodized taillights
      Kindigit door handles shaved
      All trim shaved and smoothed
      Ghost sidemarker lights
      DSE minitub
      Fuel Filler relocate
      Custom pass through exhaust exit out of lower valence
      Subframe:
      Speedtech Performance Complete Extreme Subframe w/ Viking Double Adjustable Coil Overs
      Speedtech Performance Torque Arm Rear Suspension
      9" Rear End w/ Strange Housing, Tru Track Diff
      Engine/Transmission:
      GM LS376/525 Automatic Connect & Cruise Crate Powertrain System w/ 4L70E
      Drive Junky LS Drive System w/ PS, w/ AC, black anodized
      Wheels/Tires/Brakes:
      Forgeline GX3 w/ custom center cap. 19x11.5 Front, 20x12 Rear
      Michelin Pilot Super Sport 285/30/19, 335/25/20
      Baer 6P 14" brakes with custom engraved calipers
      Baer Remaster Master Cylinder
      Additional:
      vaporworks LS tank
      Ididit Steering Column with push ignition
      DSE electric headlight door
      BE COOL Radiator
      Interior:
      will post later
      I'll add a few pictures tonight and update later when I have some more time.
      e
      Jun 2014
      Before we started!
Size:  230.3 KBName:  20170112_104001.jpg
Size:  269.8 KBName:  20170112_104222.jpg
Size:  329.7 KBName:  20170112_104342.jpg
      Jun 2014
      This is the Final Design
Size:  216.1 KBName:  File Aug 28, 5 41 23 PM.jpg
      Jun 2014
      Final Prime after all the body work!!!
Size:  78.7 KBName:  1566_1498833062662.jpg
Size:  75.9 KBName:  1568_1498833068216.jpg
Size:  65.6 KBName:  0707171717c.jpg
Size:  98.4 KBName:  0810171647.jpg
      Jun 2014
      Engine Bay
Size:  199.7 KBName:  0801171423b.jpg
Size:  178.7 KBName:  0818171711.jpg
      Amazing build! Any updates on this?
      Greg
      Aug 2018
      Do you have narrow the rear end to fit those wheel size?
      Aug 2018
      Hi there how can I get hold of you I have a couple questions about you car ???
      Aug 2018
      What kind of drive by wire gas pedal did you purchase?
      Did you narrow your rear end to fit those rims ?
      What kind of wire harness do you use ?
      No. CA
      Quote Originally Posted by Mhood View Post
      Upgrades
      Body:
      DSE minitub
      Subframe:
      Additional:
      vaporworks LS tank
      BE COOL Radiator
      Interior:
      will post later
      e
      You better reconsider your interior guy. Paul Atkins doesn't stand behind his work. I spent several thousands with this guy and it failed less than 10 miles/3 mos. later. Terrible, dishonest business guy. He looks for every reason to not honor his work or return payment for his negligent, shoddy work. Steer clear. I wouldn't take him a go-cart to work on. Let me know if you want to see all the correspondence/photos of his excuses and shoddy work.
