    Results 1 to 20 of 21
      Apr 2011
      mass
      h4 headlamp conversion
      what is the best headlight conversion for a 5 3/4 headlamp. i am looking to do this on my 1966 skylark. i know i have to use relay's which isnt a big deal to wire up i just want to use a headlamp that looks nice. anyone use a jeep tj headlamp? i saw the build where they take vw reflectors and use the glass from a t3 and glue the two together to make a t3 with a t4 build and reflector.
      Paul
      66larkgs
      Oct 2010
      Oklahoma City
      Id look for the Hella ECE or E-Code conversions.
      Jan 2010
      Somewhere out there
      Some guys had me searching for CIBIE's and all these other crazy expensive options
      and I finally found a budget and quality set of 5 3/4" H4 assemblies on Ebay on my own.
      I put a set on my 1970 442 and they're leaps and bounds better then stock.
      Got em from this guy. He sells both the low and high beam setups.
      http://www.ebay.com/itm/5-3-4-4000-H...item4cfb5679d0
      Quote Originally Posted by 66larkgs View Post
      No you don't "have to" but it does improve lighting power by giving them 14.4 Volts vs 11.x Volts.
      Apr 2010
      Pittsburgh, PA
      cibie e-code(ECE) would be best option
      boshe pretty sure makes an ece/ecode
      hellas ecode(ECE) are a bit cheaper then both but still good enough for h4 conversion and future HID conversion add-on down ther line
      I did hear the hellas tend to scatter the beam to the side and light more of the trees off road rather then strait on the road,,but still hell better then any oem sealed beam or halogen upgrade
      anything that is not e-code(ECE) wont have the right beam pattent and light distance cuttoff and will potentially blind oncommig traffic if you decide to do HID conversion later down the line with the housings
      72 buick skylark
      twin-turbo fuel injected buick 350..perhaps stroked to 370 in the works!
      Apr 2010
      Pittsburgh, PA
      so I guess the real question is do you plan to do HIDs down the line...if so get the best ece-ecode rated houseing...which are cibie...if not then i'm sure any h4 conversion housing will be good enough
      72 buick skylark
      Jul 2011
      Nashville, TN
      I'd actually opt to do h1s. H4s are not that big of an improvement.
      Drop Daniel stern lighting a note. He really knows his stuff.
      -Dave
      Project George - '66 Ford Galaxie 500 fastback
      Working on interior, body and paint now.
      Forged 306/C4. Collecting turbo parts for TT setup.
      I have tons of 65/66 galaxie parts collected. If you need something, just ask! my wife will thank you.
      H1's don't provide a provision for a low beam. Most 4 headlight systems like the OP is describing use an H4 outer (hi/lo) and H1 inner (high beam)
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Jul 2011
      Nashville, TN
      Why would you use a dual filament h4 when you don't need it? A single bulb will perform much better.
      From daniel stern:
      Quote Originally Posted by If you do much night driving, instead of H4s, put in the Hella BiFocal H1 low beams ($102/ea), which were co-developed by Hella and BMW. They will not look odd or out of place in your '66; they have glass lenses with optical facets and cuts in them. Use them in conjunction with parabolic H1 high beams ($77.95/ea). Use Narva Rangepower+50
      H1 bulbs all around ($15). These will give vastly better performance than the sealed-beams _and_ vastly better performance than any H4 conversion (much more efficient optics; entire optical area used to form the low beam).
      Illumination is broad, long-reaching, and very well focused, with no upward stray light and significantly less glare to oncoming drivers (because the light is focused where you need it) -- a substantial upgrade from the sealed beam lamps' dim, narrow tunnel of light with no side spread and excessive upward throw that causes backglare in bad weather, and likewise a substantial upgrade from the H4 lamps'
      relatively meager beam performance.
      The BiFocal low beams incorporate a "city light" parking lamp. This is a small 5w bulb ($4.24/ea) that sticks through the lamp's reflector into the lamp itself, a couple of inches away from the main headlight bulb, via a socket and grommet. "City light" is a common casual term for this. The official European/international term is "front position lamp". North American terminology calls them "parking lamps". It is _only_ a parking lamp, not capable of producing an effective or legal daytime running light or turn signal function no matter what bulb is installed.
      Electrical connection is by two standard 1/4" spade terminals. Ground one, and run the other to the vehicle's parking lamp feed. The city light illuminates the whole headlamp in a "pilot light" sort of fashion; this makes for large-area parking lamps, and if a headlight bulb ever burns out, oncoming traffic still sees you as a double-track vehicle. Outside North America, parking lamps must emit white light, the North American style amber ones are not allowed. In North America, parking lamps may emit white or amber light, and these white ones built into the headlamp are a legal form of parking lamp in the USA and Canada. In order to gain the safety benefit on your '66, you'd need to make a minor, easy modification at the headlamp switch so that the parking lamps remain lit when the headlamps are on (wasn't standard until '68): Remove the headlamp switch, unplug its multi-wire connector, run a short 16ga jumper between the "P" and "R" terminals on the headlamp switch body, right down at the base of those terminals. Make sure the ends of the jumper are neatly tucked so they won't touch any adjacent terminals, then push the connector block onto the switch, on top of your new jumper wire.
      Sealed beam "low beams" and standard H4 upgrades have two filaments in the "low beam" lamp: one for low beam, and the other for high beam. The BiFocal low beam lamps have one filament only: low beam. That's why they're so much more efficient; the optics aren't compromised to do two incompatible jobs (produce a low and a high beam). So, you rely on good high beam lamps to provide the distance throw, and leave the low beams lit in high beam mode to provide the width and fill. There's also a minor/easy mod required to keep the low beams lit when high beam is activated, achieved at the same time as you install headlight relays with relay kit RIK-CSR ($54). The RIK is not a harness, but a _parts kit_ containing all relays, brackets, terminal blocks, terminals, plugs, sockets, fuses and fuseholders. You supply your own wire and use the parts from the kit to build up your own wiring harness. Specific instructions are provided, and the concept is explained at [url
      http://www.danielsternlighting.com/tech/relays/relays.html[/url]
      .Parts are specially made premium-grade items (e.g. ceramic headlamp sockets) that accept large-gauge wire; this is not the "consumer grade" junk you can find at the parts store.
      Or, I can have my harness builder custom build you a ready-to-install harness assembly using the same components.
      Cost for this option is $139 (including parts and labour - you pick _either_ the relay kit _or_ the custom-built harness. It costs more than the $30 to $50 Chinese prefab harnesses because it is not a Chinese prefab harness).
      Installation is simple: you run the marked wires to battery positive and to battery negative, snap the harness plug onto one of the vehicle's original headlamp sockets, snap the harness sockets onto the headlamps, and secure the cable runs and relays neatly out of harm's way. Either way, parts kit or built-up harness, the in-car switches continue working normally, and you will not need to cut or otherwise disturb any of the vehicle's original wires.
      -Dave
      OK, I guess the question really is, does a 55 or 60W H1 in a dedicated low beam housing (I'm assuming you don't want to be a jerk and run a big wattage bulb on low beam potentially overpowering the oncoming driver's ability to adjust to light/dark quickly; or face fix it tickets) provide more light on Hi lense than say a 55/100W H4 on High beam, and is the improvement in lighting on low beam worth the trade off? I guess it depends on the type of driving (conditions, speeds, city/country/freeway/rural highway) you are trying to optimize.
      As far as an increase in efficiency Sterns claims, not sure what that means. More light (and I don't know how that's objectively measured) per watt? Or some other measure? I really don't care about output/watt, I'm looking at total light output.
      Regarding your claim that H4's "are not that big of an improvement", I'll assume that's an opinion unless you back it up with data. An opinion I don't share
      Greg Fast
      1984 el Camino
      Jul 2011
      Nashville, TN
      I've done the h4 upgrade on a few cars. I even ended up using the higher output tractor bulbs in am fj-60 once upon a time too. I found myself wanting around here. ( every road that is even 15 mins outside of nashville is DARK.)
      that being said, I upgraded the lights for a buddy in a 65 galaxie with the housings and bulbs that Stern recommends as well. HUGE difference and very distinct cutoff & minimal bleed. I don't have the light measurement tools necessary to give hard and fast numbers on output, but i will say that the functional difference was pretty substantial. I also did wire it so all 4 lights were on when the high beam circuit was switched on. He was running 55w low beam h1s.
      I'm planning to do the same upgrade to my car once I get through a fair amount of other things. I'll make sure to post pics of the output.
      -Dave
      cool. Too bad we can't execute a side by side comparison of an H1/H1 w/ a bifocal and h1 high bean vs. an H1/H4 more traditional design, so we would be comparing new parts vs new parts.
      Greg Fast
      1984 el Camino
      Jan 2010
      Somewhere out there
      Agreed.
      Quote Originally Posted by zombiekiller View Post
      Because that's how they came from the factory.
      Dual filaments on the outer headlights, and H1's on the inner for Brights only.
      When the brights are off, only the outer low beam headlights are on.
      When the brights are turned on, all 4 high beam headlights are on.
      It's the housing itself that does the reflecting of the light, not the bulb from what I understand.
      However, I'd be curious to see a side by side comparison of all H1's VS an H4/H1 setup.
      Apr 2010
      Pittsburgh, PA
      hmm when i through ti had things figured out danial drops new info ..
      so yea someone should do cibbie h4/h1 combo vs cibbie h4 converted to Hid with cibie h1/hi(not converted) vs Hella BiFocal H1 low beams and cibie h1 hi beams
      still think the hids would still kinda of blind oncomming traffic since its still a reflector housing anf not a projector housing..
      72 buick skylark
      Jan 2010
      Somewhere out there
      HID's require projector housings or they will blast oncoming drivers.
      So. Cal.
      Quote Originally Posted by Nothingface5384 View Post
      Not sure what HID lamps you are looking at but I did alot of research and ended up buying some Acura HID units, got a few complete units, projectors, ballasts, bulbs, housings AND wiring. Dont forget the wiring, mainly the plugs if buying used.
      The Acura HID projectors are nice. They are the auto shade type. Some of the newer ones come with the "patterned" lenses and I dont really like those and have some "clear" lenses.
      IMO a street-able HID lighting system should use projectors. Not just an HID bulb in a H-4 or other housing.
      But!! You can modify an H-4 housing to work with the projector. And thats what Im working on. Bought some decent H-4 housings from Adjure to use until I modify them for the projectors. I also bought some inexpensive H-4 housings to "test" with first. They are very inexpensive and make for a good test platform.
      Here is a pretty nice talk about some lighting systems. Just one of MANY found. http://www.intellexual.net/hid.html
      Its amazing how much effort and talk is put to lighting. I imagine it comes down to use. To be honest, if I lived in some of the dark outskirts of town I would have some auxiliary aircraft landing lamps available for use on my ride. I know, starts looking like a rally car. When you are out in the sticks it gets really dark! JR
      What I write is opinion, none of it is factual. 2010
      Even though I'm conscious it doesn't mean I'm coherent. 2011
      I'm getting better with age. Best thing about old age is I don't know any better. 2012
      Jul 2009
      New Jersey
      Let me ask a dumb question here. I'm just getting to the lights on my car and I don't really need any HIDs or anything like that. I'd be fine with a halogen bulb in a 7" round housing. Those don't need a relay do they? I got a lot more research to do.
      RJ Cilurso
      67 Camaro with a few things bolted to it
      12 Camaro with a few things bolted to it
      50 Chevy 5 window p/u with a few things unbolted
      USAF
      Jun 2009
      Southwest Florida
      Need no, but that's where the real improvement in lighting is, getting the full voltage and power to the headlights to make them perform. Relays are the easiest and safest way to do this. I'd put relays first if you're looking to spend money on headlight improvement, then go with the conversion. You can do it either way, if you need a new pair of sealed beams and know you want to switch to h4's then there's no problem doing that first.
      -- Dan
      Feb 2011
      +1 for Daniel Stern. I apologize for the length of this inclusion, but this was his response to me in regards to a 7" setup fro my camaro. - Adam
      _______________________
      I've read your articles and commentary with great interest.
      I'm fortunate to have two wonderful cars with current
      projector systems, and they are wonderful.
      Yup. Makes it harder to drive a car with poor headlamps.
      I'm building a pro-touring 1969 Camaro, and would like it to
      have as optimal a lighting setup as I can install.
      Okeh -- what goes into your definition of optimal?
      convinced me that an E-code housing (Hella or Cibie) plus
      the appropriate bulb is a rational path.
      Yup. The two you mention (Hella & Cibie) are both major brands, well made of quality materials. They aren't equivalent, however.
      I can supply any headlamp Cibie, Hella, or Bosch makes. Cibies are considerably better than Hellas. Take a look at http://dastern.torque.net/Photometry/Isocomparo.html
      These are isocandela diagrams for Cibie and Hella 7" (large round) headlamp units. The 200mm x 142mm (large rectangular) units are very closely comparable, brand for brand. Why not photographs? Because photographs of beam patterns can be very misleading even if the photographer has the best of intentions, because pixels and film work in a fundamentally different way than human eyes. First, let's look at more objective comparisons of different headlamps' beam performance. The way to do that is with isocandela diagrams, which are generated by a machine called a photogoniometer that measures the intensity of light produced by the headlamp through a large range of vertical and horizontal angles. are just like topographical (elevation) maps, except the squiggles and lines represent amounts of light, instead of elevation above sea level. The beam pattern is correctly aimed as it would be on a car on the road, and each differently-colored line represents the threshold of a particular intensity level. Each diagram is plotted on a chart calibrated in degrees. Straight ahead is represented by (0,0), that is, zero degrees up-down and zero degrees left-right.
      To get a mental approximation of the units and amounts under discussion here:
      Parking lamp: About 60 to 100 candela
      Front turn signal: About 500 candela
      Glaring high-beam daytime running lamps (e.g. Saturn): 8000 candela
      The parameters to pay attention to are the luminous flux (total amount of light within the beam), the maximum intensity and its location within the beam relative to the axial point (H,V) -- the less downward/rightward offset, the longer the seeing distance -- stray light outside the beam pattern and effective beam width (contained within the dark-turquoise 500 candela contour)
      Things to notice about these two diagrams:
      (1) The Cibie produces a much wider beam pattern than the Hella. The 1000 candela line of the Cibie's beam pattern extends from 25 degrees Left to 25 degrees right, while the 1000 candela line of the Hella extends from 18 degrees Left to 20 degrees Right. At a distance of 50 feet from the car, this means the 1000 candela-and-brighter portion of the Hella's beam is 10.5 feet narrower than that of the Cibie. The 300 cd contour of the Cibie's pattern is *far* wider, extending from 43 degrees Left to 50 degrees Right, compared to 26 Left to 25 Right for the Hella. This means the overall useful width of the beam pattern at 25 feet from the car, as perceived by the driver, will be 40.7 feet for the Cibie and 22.3 feet for the Hella.
      2) The total luminous flux (overall amount of light) within the beam pattern is 695 lumens for the Cibie, 463 lumens for the Hella - the Cibie is 50.1% more efficient. (the TLF data is listed as "Luminous Flux" in the readings up above the isocandela diagram)
      The high beams for these two lamps (isocandela diagrams not yet scanned in) are very similar in overall performance and amount of light -- the critical difference is that the Cibie's high beam hot spot is located closer to (0,0) and closer to its low beam hot spot. The Hella's high beam and low beam hot spots are separated by a fairly large vertical amount, such that setting the lows where they belong results in most of the high beam light going up in the trees, but pulling the high beams down so they send light straight ahead puts the low beams 10 feet in front of the car.
      Get the Cibies. If you stay with stock wiring, you need to stick with stock-wattage bulbs; options are plain ($9), high output ($13) or ultra high output ($18). Given the thin original wiring, you will want to put in headlamp relays whether or not you intend to increase bulb wattage over the stock level. This can be achieved with relay kit RIK-2, $49. The RIK is not a harness, but a _parts kit_ containing all relays, brackets, terminal blocks, terminals, plugs, sockets, fuses and fuseholders. You supply your own wire and use the parts from the kit to build up your own wiring harness. Specific instructions are provided, and the concept is explained at http://www.danielsternlighting.com/t...ys/relays.html .Parts are specially made premium-grade items (e.g. ceramic headlamp sockets) that accept large-gauge wire; this is not the "consumer grade" junk you can find at the parts store. Or, I can have my harness builder custom build you a ready-to-install harness assembly using the same components. Cost for this option is $139 (including parts and labour - you pick _either_ the relay kit _or_ the custom-built harness. It costs more than the $40 to $90 Chinese prefab harnesses because it is not a Chinese prefab harness). Installation is simple: you run the marked wires to battery positive and to battery negative, snap the harness plug onto one of the vehicle's original headlamp sockets, snap the harness sockets onto the headlamps, and secure the cable runs and relays neatly out of harm's way. Either way, parts kit or built-up harness, the in-car switches continue working normally, and you will not need to cut or otherwise disturb any of the vehicle's original wires. If you upgrade the wiring by either method, use Narva 100/90w bulbs, $20/ea.
      Please specify whether you wish lamps with ($75.95/ea) or without ($74.95/ea) built-in parking lamps. This what we're talking about is a small 5w bulb that sticks through the lamp's reflector into the lamp itself, a couple of inches away from the main headlight bulb, via a socket and grommet. "City light" is a common casual term for this. The official European/international term is "front position lamp". North American terminology calls them "parking lamps". It is _only_ a parking lamp, not capable of producing an effective or legal daytime running light or turn signal function no matter what bulb is installed. Electrical connection is by two standard 1/4" spade terminals. Ground one, and run the other to the vehicle's parking lamp feed. The city light illuminates the whole headlamp in a "pilot light" sort of fashion; this makes for large-area parking lamps, and if a headlight bulb ever burns out, oncoming traffic still sees you as a double-track vehicle. Outside North America, parking lamps must emit white light, the North American style amber ones are not allowed. In North America, parking lamps may emit white or amber light, and these white ones built into the headlamp are a legal form of parking lamp in the USA and Canada.
      HOW TO ORDER:
      Orders may be sent via e-mail to: [email protected]
      You may also voicemail or fax your order toll-free on 1-866-861-8668.
      Please note this is a recorded orderline only. If you wish to speak to me
      in person, please use 416-766-2327.
      PLEASE INDICATE:
      The quantity of each item you wish
      The address to which you want the items shipped, if it differs from the
      billing address
      All items are warehoused in the USA. Please state the type of shipping you
      wish -- DHL, FedEx, or UPS ground shipping is standard on shipments within
      the US; all other service levels are available on request. Shipments to
      Canada go via Postal EMS unless otherwise specified. If you have an
      account with one of the carriers I use, I'll be happy to ship on your
      account; just provide the details with your order.
      Please also state whether the delivery driver has permission to leave the
      parcel at your doorstep if you are not available to accept and sign for it
      in person.
      CREDIT CARDS:
      I accept Visa and Mastercard. Orders are processed securely and customer
      card info is not retained after processing your order.
      The following information is required in order to process a credit card
      order:
      Card type
      Card number
      Expiry date
      CVV code (last group of 3 or 4 digits on back of card)
      Your name as it appears on the card
      Billing address
      Phone number
      PAYPAL:
      I accept PayPal. If this is how you wish to pay, please send your
      shopping list and I will send you a PayPal invoice from which to pay.
      Please _do not attempt_ to pay by PayPal until you have received a PayPal
      invoice for your order.
      I look forward to hearing from you.
      Highest Regards,
      Daniel Stern
      Jan 2010
      Somewhere out there
      Quote Originally Posted by AintQik View Post
      Not necessary, but definitely beneficial.
      I'd do the 7" H4 bulb housing upgrade personally, they're only $20-$30 on Ebay.
      They are glass, and they are better then the factory headlights.
      Jan 2010
      Somewhere out there
      Quote Originally Posted by JRouche View Post
      He's talking about regular halogen housings people putting HID bulbs into that aren't designed for that.
      The Acura HID housings are projectors designed for HID bulbs.
