    Results 1 to 9 of 9
      Oct 2005
      New Washington, IN
      Brake lines leaking
      I installed new brake lines, and used a line wrench to tighten them ,snug. I am getting drips at just about every connection. Lines are new, hoses are new, calipers are new. On the calipers I used copper washers on both sides of the fitting. At the prop valve I am getting a leak too. I did not use any teflon tape or paste. Installed all with dry threads.
      1971 Camaro 427 in waiting
      1988 C1500 Daily Driver
      Cartersville, GA
      I'd check the quality of the flares...if they are pre-bent lines, they are rarely an issue, but its worth checking, along with the fittings and threads themselves. You may just not have the fittings tight enough. Flares shouldn't need any tape or other sealants, but if you have an aftermarket prop valve with NPT fittings, the NPT side will need tape or thread sealant.
      Joe Hinds
      Feb 2002
      Santee, CA
      As Joe mentioned, pre-bent lines are rarely an issue, but if your brake lines were custom made, make sure they didn't use a 37 degree flare. 37 degree is used for AN fittings, but brake lines use a 45 degree double flare.
      Apr 2004
      Cedar Rapids, IA
      tighten the nut then back it off and retighten. You will find when you retighten a second or third time you can turn the nut further. As stated above make sure the flare are good and also that the part your tightening to is not bunged up.
      Oct 2005
      New Washington, IN
      Thanks for the tips. Yes they are prevent lines. Prop valve is gm. I'll check them out again.
      Jun 2006
      Katy,TX
      I took apart a line to move things around and thought I had it tight and it leaked(GM line). Had to really crank it tight. As the others said sometimes there can be a nick in the flair on either end.
      1978 Black Trans Am 455 Edelbrock heads [email protected] through mufflers on pump gas
      1981 Trans Am 400 stock type motor
      79 Camaro getting a 500" 695 hp IA2 Pontiac motor
      1965 GTO project car
      470ci/Chevy dual quad 409 604 HP 64 Impala SS project
      2004 Pulse Red GTO
      Midwest
      I like to dab a little assembly lube on the threads to help them squeeze smoother without galling... this way, you feel the flares tightening together rather than threads galling.
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      Oct 2010
      Eden, WI
      Are they stainless steel lines? They are much harder and more difficult to seal.
      Oregon
      Quote Originally Posted by rohrt View Post
      X2...loosening and retightening is the best way to seat the sealing surfaces without over-torquing the fittings.
      Tobin
      KORE3
      It's what I does.
