    Results 1 to 7 of 7
      Iowa
      How much clearance for these bushings?
      I am making my own steel greasable lower bushings like the pic below. How much clearance should I make where it pivots?
      1980 Chevy Monza, 305/TH350 soon to be LS1/T56
      http://www.forums.h-body.org/viewtopic.php?f=20&t=26442
      May 2002
      Northern California
      you going full metal? average is .005-.009in ra you can run delrin abit tighter
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Iowa
      Yeah, full metal. Thanks for the average, never made anything like this before. First set is at .004, so I will open them up a bit.
      Lawrenceburg, TN
      So. Cal.
      Cool!! I thought I was the only one messing around with making metal bushings. I made some, for the front. I started out with some 4140PH bars. It turned pretty good, not as nice as 4140 annealed.
      They were solid bars so I had to take alot out of the center. I drilled them out to minus .150" then bored the remainder out to within .001" for my ending number of .005" of clearance. I made the bushings (inner and outer shells). The hard part for me was getting a decent .001" for the entire bore. I was able to get a decent .001" dimension for the inner part of the bushing. Outside turning. But getting the bore of the outer part of the bushing was time consuming. But I got the fitment to .005" throughout for all four bushing parts (I only needed the lower bushings)..
      Good to see some other folks making their own parts.. JR
      What I write is opinion, none of it is factual. 2010
      Even though I'm conscious it doesn't mean I'm coherent. 2011
      I'm getting better with age. Best thing about old age is I don't know any better. 2012
      May 2002
      Northern California
      Quote Originally Posted by 80 MONZTA View Post
      Problem is if you are not machining your own parts the tolerances will push it to tight or just be so wide.
      Vince
      Jan 2010
      Elk River, MN
      Man, .005-009" seems like a bunch. When I'm designing around a bushing, .001" clearance per 1" of diameter is the rule of thumb. I'd keep it at .004" if it were me, but if other bushings are going .005-009 I suppose they have a reason. Only thing is, the main reasons for bushing clearance are lubrication, and misalignment of components, but in a case like this, the mounting bolts are able to take a whole bunch of misalignment versus what a loose bushing fit will get you.
      -matt
      Edit: When I say bushing here, I'm using it interchangeably with sleeve bearing, in case there's any confusion/misunderstanding.
