    Results 1 to 20 of 21
      Calculating Rear Roll Center for Leaf Spring Cars
      So, I understand how to calculate the roll center for the front with control arms. How do you apply this to the rear on a leaf spring car?
      Then, what are some good ways to adjust the roll center of the rear?
      dennis68 Guest
      There is an imaginary line that runs through both of the spring eyes, the height at which the wheel vertical center line intersects is the RRCH. Changing the RRCH on a hotchkis type suspension is very limited and requires either new parts or a friend that can de-arch springs.
      Last edited by dennis68; 05-25-2005 at 06:11 AM. Reason: clarification of wheel center line
      Jan 2003
      Arizona
      So how do extreme lowering blocks (say 2" plus) affect the geometry? Where the wheel centerline may be moved above the plane created by the front and rear spring eyes. Also, I assume a shorter tire has an impact since it moves all of the points closer to the ground.
      ________________
      Steve Chryssos
      dennis68 Guest
      My bad, I should prefaced that statement with "to properly" before making any definitive statements. I would think anyone serious enough to be researching moving RRC would not be running 2" blocks on the axle, thats just me.
      Yes, shorter tires would lower the RRCH but thats not a reasonable change as what you gain in the shorter sidewall makes more of impact than the 1" or so of lowered RCH. I think most people already have their wheel /tire combo set up and wouldn't be likely to change it to make a small adjustment.
      Jan 2003
      Arizona
      Oh. I thought it would be bad. Do you want the three points to interesect? Front eye, axle centerline, rear eye? Or is it better if the axle centerline is higher than the other two points.
      I've often considered raising the front spring eye location (a lot of work) such that the line created by the front and rear eyes is at least horizontal. Then I could return to springs with a little more arch.
      ________________
      Steve Chryssos
      dennis68 Guest
      Quote Originally Posted by streetfytr68
      Oh. I thought it would be bad. Do you want the three points to intersect? Front eye, axle centerline, rear eye? Or is it better if the axle centerline is higher than the other two points.
      It really doesn't matter where along the spring pivot axis the vertical CL intersects except to determine RCH. With a 285/35R18 the RRCH would be ~12.9" if you positioned the spring so that the horizontal wheel centerline was in direct line with both spring eyes.
      Repositioning the spring mounts could be advantageous however, to modifying existing anti's. I don't know if moving the spring pivot locations would have a measurable impact on roll steer characteristics....anyobody have any ideas?
      Jun 2002
      Benicia, CA
      Leaf Spring Eyes
      I read on a few leaf spring sites that for advantageous cornering the front spring eyes should be about 9" below the rear spring eyes, as well as moved inward 1-3" each. We had a discussion about this a while back on the old board.
      I currently have about 9" lower front spring eyes (rear sliders), and 3" inward mounting of each front spring eye. It also looks like the line between the center of the spring eyes goes through the center of the axle, maybe a tad higher than the center.
      Jeff
      1971 RS Camaro: PAINKILLER
      Central CA USA
      Here is some leaf spring tech from AFCO.
      Their website link to their tech page is dead but I found last years tech page on the "Wayback Machine" here: http://web.archive.org/web/200411260...art/leaf.shtml
      Jan 2003
      Arizona
      Awesome. I see it now. Doesn't matter how much above or below the imaginary line the axle centerline is with respect to RCH The intersection of the vertical line created by the axle centerline and the imaginary line.
      I'd say that file needs to be added to our little fountain of knowledge.
      ________________
      Steve Chryssos
      Jun 2002
      Benicia, CA
      That's my setup!
      That's exactly what my setup looks like. I still am a ways off from testing it on the road though...
      Jeff
      Chico, California Nor-Cal
      Rrc
      On the 2nd gen Camaros it is popular to relocate the front leaf spring eye 1" higher to raise the RRC, and lower the car about 1/2". By that graph it appears that it would accomplish both by just lowering the car, not by the geometry change. I'm thinking of doing this to reduce my 1" lowering blocks to 1/2". It wheel hops terribly when hooked.
      dennis68 Guest
      Quote Originally Posted by ks71z28
      I'm curious what theory describes raising the RRCH? On almost any leaf sprung car RRCH is going to be at least 12-14". Ideally RRCH should be shorter than that in almost any situation.
      Nov 2002
      state of confusion
      What somebody needs to do is post is Figure 17.44 from RCVD (page 662).
      There's a kinematic construction line that can generally be taken as 0.375L. This is essentially a virtual link between the front eye and wherever the 0.375L intersects the center of the leaf as seen in side view. The leaf spring suspension's own roll axis is parallel to this construction and intersects at the rear roll center point in the pic that's already been posted. An 0.375L virtual swing arm is also parallel to this construction, and this extends forward from the axle center. This virtual swing arm is what defines the fore/aft motion of the axle at the leaf attachment lateral coordinates. And the slope of all three is the rollsteer percent.
      Note that this is kind of theoretical, as bushing compliance, lateral deflection of the shackle assembly, and torsional deformation in the leaves themselves is likely to throw the constructions "off" a bit. Even the slight flattening or exaggeration of the curvature as the suspension moves has a slight effect.
      Norm
      Gone but not forgotten dep't:
      Nov 2004
      Astoria, NY
      A couple of months late, I know. Moving the spring eye up isn't done to raise the RRC, but to improve Anti Squat as well as lower the car a bit. I believe Herb Adams used that trick when he was racing Trans Ams.
      1977 Trans Am
      Nov 2004
      Forney, TX
      Quote Originally Posted by StaticAGE
      ....Moving the spring eye up isn't done to raise the RRC, but to improve Anti Squat as well as lower the car a bit. I believe Herb Adams used that trick when he was racing Trans Ams.
      How exactly is this accomplished?
      __________________________
      Boyd
      1972 P/T Style Chevy Short-bed - coming soon
      Specialty Auto Services
      Central CA USA
      Quote Originally Posted by Boyd
      On a second gen you have the bolt hole lower than on a first gen (similar bracket, but it's got a lower hole), you can cut a "window" in the top of the mount, then the front spring eye has a little room to go higher. Herb Adams says 3/4" higher is max available.
      There isn't room on a first gen to do this mod.
      Your rear ride height will drop almost 3/4".
      Anti-Squat will increase.
      Nov 2004
      Norway
      Country Flag: Norway
      Here you go: (Though a bit late!)
      So (ignoring the fact that the spring bends and 'moves'), to get roll understeer, I want the point 'R' to be higher than point 'Q', giving a slope lower in the front on the roll axis? And the front portion of the spring (between the front spring eye and the axle) to be as straight/flat as possible?
      From other books I have read, I have just thought getting the spring eyes almost at the same level (a little up in the rear), to minimize the built in roll understeer. Is the rear rollcenter height given from the line drawn through the front spring eye and the frame side of the shackle, as shown on the picture above, or through the spring eyes (ignoring shackle length)?
      Last edited by Chevy350; 03-12-2006 at 04:03 AM. Reason: Reading posted dates isn't a priority....
      Thanks, Christian (@v8power.net)
      '77 Caprice
      '71 Chevelle Nomad - Perfect for roadtrips!
      Nov 2004
      Forney, TX
      Thanks DP.
      Boyd
      Quote Originally Posted by David Pozzi
      So that's it for the first gen? No room at all?
      May 2002
      Northern California
      ...ahh you can but it involves cutting up the floor pan. It can get ugly.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
