View Full Version : Tire width size help
71 pro olds
09-30-2009, 06:41 PM
Does anyone know how wide and tall is a 305/35 22 series tire on a 22x12 rim. I am looking to run this on a 71 442. I know that I will have to make new wheel tubs, But I am unsure if it will fit in the factory frame rails with the new tubs. For the front I plan on running a 235/35 20. thanks:idea:
The Stickman
09-30-2009, 06:55 PM
It is 12 inches wide 30.4 inches tall. The front is 10 inches wide and 27 inches tall. I use this and it has helped a ton.
http://www.rims-n-tires.com/rt_specs.jsp?postId=906
1-CLN-SS
09-30-2009, 07:14 PM
Why dont you go with a 315/25/22 instead.Here are some on my SS with 22x11 rims
https://static1.pt-content.com/images/pt/2009/10/3152522004-1.jpg
71 pro olds
10-01-2009, 12:35 PM
A 25 series tire is too small for what I need. My motor is a 632 merlin and if needed I will back half the car, so custom wheel tubs is a must. The rear is being shortened 4 inches. Really would like a 40 series or bigger and atleast a 14 inch wide tire. Still need to research what is available for tires out there.
