Results 1 to 17 of 17
Thread: Body Panel Fitting
02-08-2005 #1
Body Panel Fitting
Ok, I'm new at this part of the game and would appreciate any tips. I have new (repro) front fenders that I'm fitting on the body along with the old nose pieces (which look to be repros too, may need to replace), new hood, etc. Naturally, they're not lining up well on initial assembly. I want to try to fit them on before I do any finishing of the panels. I'm basically talking about the front end (fenders, inner fenders, upper and lower nose pieces, hood), doors, trunk lid. Here is my thinking as to the order of tasks - please let me know your recommendations from your experience...
1. initial fitting of panels, modify as necessary for best fit
2. remove panels
3. perform body work - straighten, prime, paint back side with zero-rust or regular paint? recommend spraying edges of panels with base for cut-in?
4. re-assemble panels, block sand, prime, repeat
5. ready for color
02-08-2005 #2
Banned
- Join Date
- Nov 2003
- Location
- Maine
- Posts
- 1,076
tom
depending on color, i would panel paint the vehicle, but let us know color then we can go from there, even if its a mettalic the new paints are so far ahead of yesterdays paint that there is little trouble with panel painting a car, however i do like to paint everything at same time.
now yes pre-fit panels, hoeing out holes where needed, and getting everything aligned, take note to where and how many shims are needed, as this is key into getting it back together.
next do all body work inside and out, and prime and block sand, then prime and block sand some more, i would then paint back of panels, with your choice, something semi gloss to not draw attention to itself, i like evercoats paintable undercoating, it dries in 30 mins and leaves a bit of a textured finish, its cheap too, 6 bucks a can, best stuff out there, then tape off inside of panels and prep and clean for paint, if you do not mind overspray on inside of panels i would not tape them, there are only a few spots you will ever see once done, goodluck
let us know
if you do paint with fenders on just tape off engine bay, etc and do all basecoat at same time, have doors off and tape interior off and do jambs all at once, much cleaner for someone who does not do alot of paint work, as you can get some bad tape lines,, goodluck
jake
02-08-2005 #3
